Torque Brace Issue Solved !
Old Jan 28, 2006 | 08:30 PM
1stbluSS's Avatar
Exclamation Torque Brace Issue Solved !
I have solved the TQ brace issues for the 2005 SS/SC. I will post pictures sometime monday or tuesday. My card reader is at work . The brace rubs in two spots. One the eyelit of the damper hits the mount. Two the top bracket with the three holes in it hits the mount when turning left because of the pressure on the body. This is easily solved. A longer bracketwill move the damper completely away from the motor mount. That will be solved. What I did was I took a blow torch and completely got rid of the wall for the hole on the bracket that is closest to the firewall. I then ovaled out the other holes. This allowed me to slide it down a little. To fix the bracket rubbing against the motor mount I took a file bit and opened the holes a little more. This allowed me to slide the bracket closer to the motor. Now I have double the spacing and no rubbing. I also did some other things today that worked out well. Unfortunately the ticking in my motor still hasn't gone away. I am getting it serviced monday though.
__________________
2005 Cobalt SS/SC
Arrival BlU Metallic
Blue 3.15 in pulley @ 14.5 psi
Blue torque brace
Blue neon underbody kit
BPV Mod
Custom CAI w/ k&n drop in
Old Jan 28, 2006 | 10:48 PM
Nuclear's Avatar
lets see the pics when you got time to post
Old Jan 28, 2006 | 10:55 PM
Chevypowered's Avatar
personally i think those torque braces are a joke and should only be used as a temp. fix
Old Jan 28, 2006 | 10:56 PM
1stbluSS's Avatar
Once you fab it to fit correctly they work pretty damn good. It is a simple idea actually.
Old Jan 28, 2006 | 10:58 PM
lucky523's Avatar
The only thing I did was adjust mine and the rubbing stopped instantly. No blow torch needed.
Old Jan 28, 2006 | 11:07 PM
1stbluSS's Avatar
I wanted maximum clearance. I dont want to have to adjust it all the time. You will find that after time you will need to adjust yours again. Im lazy so I just fabbed it so I could cut that step out.
Old Jan 30, 2006 | 04:18 PM
1stbluSS's Avatar
Well now I have pictures.
So first picture is the bracket for the TQ brace as it is from Cynic
The second picture is the mount where this bracket is applied to
The third image shows what I did to make room for the TQ brace. As you can see I melted the wall off of the third hole and ovaled out the others. I also cut away at my washers to allow me to push the mount to the right. I didnt have smaller washers avail.
I painted it silver afterwards good as new
The forth image shows how much space I now have between the bracket and the motor mount. Before there was enough space for maybe 3 pieces of paper.
The next two images show how much space I now have between the damper and the motor mount.
This will solve all of your rubbing problems
Old Jan 30, 2006 | 05:05 PM
MOD MONEY's Avatar
Yours is different than mine. I worked on my bottom bracket today. Just bent the hell out of it so its closer to the engine
Old Jan 30, 2006 | 09:30 PM
MOD MONEY's Avatar
Just got back from drivin around hard as hell, even gave a cadillac northstar a run for, and the bracket I bent works. No vib at all and wheel hop is at minimum.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
cavfiredesire
Oct 3, 2015 08:02 PM
Delta coupe
Sep 30, 2015 08:11 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
