Torque Pattern for LSJ Valve Cover
Old Aug 1, 2011 | 10:40 PM
BlkWdoSS's Avatar
Ok, I have the torque specs for the valve cover:
Cam Cover to Cylinder Head Bolt
8 N·m
71 lb in
but what is the actual torque pattern for the valve cover?
l8r,
PD
Old Aug 1, 2011 | 11:18 PM
Powell Race Parts's Avatar
no pattern specified, but if you start at the middle and work radially all the way out you wont be far wrong. 89 inch lbs is what my manual says, not 71...
Old Aug 1, 2011 | 11:44 PM
BlkWdoSS's Avatar
ok thanx, I was going off the torque specs that are stickied in this forum. that maybe why mine is pissing oil everywhere... ugh fml sometimes lol
l8r,
PD
Old Aug 1, 2011 | 11:47 PM
its easy when you put the cover on, to have the seals drop. they do if properly cleaned, stick well. there is only one correct way to put them on, look at the seals.
if you have trouble like that use a little dab of blue hi temp silicone in the cover grooves to keep the gasket in place. take care that the little spark plug ones dont drop out. good luck
Old Aug 2, 2011 | 12:59 AM
BlkWdoSS's Avatar
I'm fairly positive that they didn't drop, I double checked with a flashlight to see. I think its the torque that is the problem, I'm leaking from the driver side where there are fewer bolts to hold everything down.
L8r,
PD
Old Aug 15, 2011 | 06:53 PM
Subd
Old Aug 15, 2011 | 10:57 PM
G11's Avatar
G11
thats where my buddies was leaking...between the cam postioning sensor and the other cam turned out to be the gasket
don't know if that will help but that is what his problem was
Old Aug 18, 2011 | 05:43 AM
BlkWdoSS's Avatar
well pulled the cover off and found that the rubber gasket had turned under next to the cam position sensor and was allowing oil by there. Added some blue silicone to get everything to stick back the right way and torgued it all done radially. No leaks from that part now. Just gotta get my rear main seal fixed and oil leaks will be done lol
l8r,
PD
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
