Trunk problem
Old Apr 4, 2009 | 01:33 AM
TurkSS's Avatar
Trunk problem
Okay so i disconnect my battery only i didn't realize the only key i have is the valet key. so now i have no access to my trunk. How can i get in there? Can someone take a picture of the release inside? I can fit my hand in there but don't know what or where i am feeling. Open to suggestions.
anyone?
Old Apr 4, 2009 | 01:34 AM
StockSS's Avatar
no keyhold on the trunk?
oh wait valet key. lol
how would you open the trunk if you can get in the trunk???
Old Apr 4, 2009 | 01:36 AM
Shane08's Avatar
valet key?
Old Apr 4, 2009 | 01:38 AM
TurkSS's Avatar
I opened the trunk before the battery was disconnected then i closed it after not realizing that i only have the valet key. Meaning all i can do is open driver door and start car only no power so i can't do anything. If someone can tell me where exactly the seat lever or whatever is i might be able to shove my arm through and open it up. anyone tell me where this latch or lever is?
Old Apr 4, 2009 | 01:41 AM
~Mike~'s Avatar
agreed, valet key? And if you can reach the latch for the trunk, then you have one big ass hole in your car. Have you tried the button inside the car?
Ur in trouble...the lever for the seats to fold down is in the trunk. You can't get to them unless the deck lid is open. Locksmith....?
My car came with two identical keys, what is a valet key? and how can it only operate ignition and driver door? All the locks on my car are keyed the same
Old Apr 4, 2009 | 01:42 AM
TurkSS's Avatar
well how far in is the release because i can actually shove my arm between the seats and feel around in the trunk. I will probably go to the dealer when they open and ask them to cut me a key.
Old Apr 4, 2009 | 01:46 AM
~Mike~'s Avatar
the latch is way back near the upper half of the opening in the trunk. your arm isn't long enough to reach that far. unless ur some 8 ft. tall skinny feller, then you might have a chance
hook jumpers up to your car from under the hood to get some power. I'm sure you've got a set and someone elses car nearby that you can use
Old Apr 4, 2009 | 01:48 AM
TurkSS's Avatar
so if i connect jumpers even though my battery is not connected i may be able to get enough juice to pop it?
Old Apr 4, 2009 | 01:55 AM
~Mike~'s Avatar
well yea. Jumpers are for starting the car when the battery dies and it takes way more power to crank the starter than it does to pop the trunk latch. And having your battery disconnected is basically the same thing as it just being dead. Attach the cables to the positive lead sticking out of the fuse box and the ground on the strut tower. That's where ur supposed to jump the car from anyway, that's why the positive connector is up there and the ground clearly labeled
Go give it a shot and come back and lemme know how it worked
Old Apr 4, 2009 | 01:56 AM
StockSS's Avatar
you sound like your screwed lol. i have a buddy with a shaved keyhole but he has 2 keys so if one runs out he can still pop it.
would suck if the popper stopped working lol
Old Apr 4, 2009 | 02:05 AM
TurkSS's Avatar
well problem solved. Thanks mike just hooked it up enough to pop my trunk connect my battery and walah done deal. Thanks for the help everyone
Old Apr 4, 2009 | 02:06 AM
~Mike~'s Avatar
No problem...that's what us css.net folks are for. Glad you got it all taken care of
Old Apr 4, 2009 | 02:26 AM
EmperorJJ1's Avatar
son of a bitch you mean i fucked up my arm trying to open the trunk with that emergency latch for no reason.
Old Apr 4, 2009 | 02:38 AM
leviticus88's Avatar
Still no answer to Valet Key. How did you get one?
Old Apr 4, 2009 | 02:42 AM
~Mike~'s Avatar
I guess so? lol I can't believe neither of you thought about that before hand. We've all been under the hood, you had to notice those leads and know what they were for lol
Old Apr 4, 2009 | 02:52 AM
EmperorJJ1's Avatar
lol ya ive ran 3 sets of wire to said post. i just figured with the battery out of the equation it wouldn't work
Old Apr 4, 2009 | 02:54 AM
~Mike~'s Avatar
Ahh...no sir. By hookin up the jumpers it basically re-routes around the battery to give the car power. Whether it's dead/not hooked up, it makes no difference. But now you know in case there's a next time lol
In case you can't tell, I have had alot of dead battery problems on past cars. I even had a car that had no battery, i carried around a jumper box lol
Old Apr 4, 2009 | 03:04 AM
EmperorJJ1's Avatar
i probably should do that because my keyhole in the back is for a different car (traded trunks) and the gigantic 2 15s box bolted to the floor makes entering the trunk difficult from the front even thou i have the seats down all the time
Old Apr 5, 2009 | 12:14 AM
TurkSS's Avatar
as for the valet key. Thats the key i got when i bought the car. didnt know it was one until last night. well lessons learned
turbochargedss2012
Sep 20, 2023 12:17 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
