turbo LSJ help please
Old Jan 20, 2012 | 11:06 PM
burstss's Avatar
I turboed my LSJ256s ext tip bullseye turbo, I was wondering how much boost can i safely run, and how much hp can i make on stock internals?? also im looking to buy new fmic and piping along with motor mounts if any have any for sale.
Old Jan 20, 2012 | 11:14 PM
donkeyballs's Avatar
i would say between 400-450whp is starting to really push it and i know people are running 26+psi on the s256 but everything depends on the tune and how you drive your car.
Old Jan 21, 2012 | 06:00 AM
ULWizSS's Avatar
yeah seems like most say under 450 is safe anything over that is not. My buddy is on 26psi and meth on his. I am a EFR so i cant coment on mine.
He has a semi built motor too so he is def around the 450 area currently.
Old Jan 21, 2012 | 11:01 AM
yellowss7590's Avatar
Yea with stock pistons and rods I'd say stay around 400ish to be safe
Old Jan 21, 2012 | 11:14 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
21-23 psi would be fairly safe
Old Jan 21, 2012 | 07:15 PM
ULWizSS's Avatar
If i could only get there right now. Stock system is not supporting 21 on the EFR for me.I need to add my 80's, Boost Reference,Fuelpump sitting in the box to crank it anymore. But yeah looking for right under 450
Old Jan 21, 2012 | 07:45 PM
You running stock internals and valve springs right now?
Old Jan 21, 2012 | 08:51 PM
ULWizSS's Avatar
Yeah i still dont have the head on yet. Talked to Steve at ZZP today yes on a sat. So he is calling me Mon Tuesday and we are going to talk bottom end and place the order for the. Already have a decent deposit down so they will most likely start it soon. Once its done car will be picked up by them. Motor swap and head on. Retuned with E85 and a 93 Tune and shipped back home to me.
Cant wait to track this thing.
Old Jan 22, 2012 | 12:55 PM
Killa SS's Avatar
how are they gonna do the double tune? give you the file for each tune so u can load it in to the car with HPT?
Old Jan 22, 2012 | 12:56 PM
ULWizSS's Avatar
yep you got it, i dont have a need for two pcm because of hpt.
Old Jan 22, 2012 | 12:58 PM
Killa SS's Avatar
kool good to know. they'll be getting my car in june for a full build. i wanna do E85 for the lower temps and more power, but wanna retain the capability for gas so i can travel, not many places in michigan have E85. i know of a couple around me but not more then 7 stations with in 40 miles. lol.
Old Jan 22, 2012 | 01:02 PM
ULWizSS's Avatar
Yeah not me i have maybe 3-5 all a hour away. That why i want both tunes. The cobalt is suppose to become a track car mostly. Still looking for a DD AWD with a good amount of miles. Once that happens the cobalt will be stictly a toy. Goal is to buy a tank and stockpile it here.
Hell it should sit at over 500 once i get it back on almost either tune. And 400ish is kind of scary if you dont know how to control a car.
Old Jan 22, 2012 | 01:06 PM
Killa SS's Avatar
that'll be nice. my car will be my summer car. looking for an AWD as well, but leaning more towards a diesel truck. as i need one to haul my other toys, dirt bikes and Sand rail.
Old Jan 22, 2012 | 01:08 PM
Chevycobaltss3's Avatar
My car should be a only track car... lol but its not.. but in all honesty op if your worried aboust safety or reliability of the car . I'd run no more then 22lbs on your turbo.... I've had a couple heads lift off the block...
Old Jan 22, 2012 | 01:09 PM
startingline05's Avatar
Run e85 and crank the the boost and timing up. Well worth it on a turbo lsj.
Old Jan 22, 2012 | 01:10 PM
Stock springs and head studs I was running 28psi on the s252et. Car ran just fine.
Old Jan 22, 2012 | 01:11 PM
Killa SS's Avatar
how much psi till the heads started lifting tho? were head studs used? just info id like to know. i have ARP head studs. just curious about it.
Old Jan 22, 2012 | 01:12 PM
ULWizSS's Avatar
what if i am not once my motor is done here shortly. Its a 2.1 with the girdled installed paired with all the other zzp related parts and a zzp stage 2 ported head an stage 2 turbo cams. Whats my limit going to be in your opinion with the EFR 6758.
On both 93 and meth tune
And on Straight E85.
Old Jan 22, 2012 | 01:15 PM
First off the 252 isn't that big whatsoever. Pushing 28lbs may make the car quicker but run that 28lbs for some time and you'll understand what I am saying... I commented on reliability , not power.. he's asking safely. Not how long will it last if i push it to hard.. running e85 or meth doesnt mean you lose all other worries like head liftin and ect..
[/B]
Old Jan 22, 2012 | 01:17 PM
The head lifting all depends on head bolts and ect. All the guys who lift the head all ran stock head bolts. So is say safely 24-25 on your setup. Anything more is just asking for issues. Since your stock internals.
Old Jan 22, 2012 | 01:19 PM
mrbelvedere's Avatar
it si going to be different for each engine but if you are worried about it get the L19 arp studs
Your limit will be fuel of course.... It's all dependant on that.. the internals should hold great .. just fueling. If you get 1000cc injectors, along with the aeromotive pump and a referenced fuel system I can see 600+ easy .. ... Boost .. all dependant on fuel.
Old Jan 22, 2012 | 01:21 PM
I'll give an example. Marks car is a good one... His issue is fuel. If he had larger injectors he'd be able to push his engine more but he was already going static.
Old Jan 22, 2012 | 01:25 PM
ULWizSS's Avatar
I have 80,boost reference with option 2,and the aeromotive pump sitting in a box here now. Issue i have is on 60 and stock and once i try and crank it from 20psi to 21 my afr starts going super lean. Looks like fuel cant catch up past that 17.5
Old Jan 22, 2012 | 01:29 PM
Ure issue sounds like pe error. If your tuning it all you need to do is dial in your maf and your pe. Unless this is on e85 then I can see it. The Redline 6758 I tuned is using 60s and when we had him at 22lbs his idcs were 70% i think and afr was 11.9 ... Do if you tune in everthing and its still doing it then your pump is prob a weak one...... (The force is not with that pump).. sarcasm .. I had to
