turbo swap
Originally Posted by sunfirejoe
lol i have hptuners sitting at home so im step on that , and yah like i said im thiking possibly going to 25 psi, but im gonna start small like 12 psi and see how the motor likes it, it might make me lsower to begin well see, but yah, i hope to only use at the most about 10 silicone connectors, at 1st, due to fabbing i wanna prove it to work than ill worry about welding it all
yea 25psi will rip the hell out of stock internals.
Man u guys are doing this teh hard way
Use your ss/sc manifold and get an adapter plate made to mate ur tb to the top of the intake mani and find a smaller belt. RIU did on their solstice
60lbers are fine...I'm at 72%idc on mine already...if anything id go bigger but the hpt/gm map for injectors only supports up to 63.49lb/hr
This eliminates intercooler routing issues and give u an efficient base to start with
also note that twincharge had to switch to a copper head gasket and studs around 23psi cause the gasket was blowing out.
I'd run a used holset hx35w and will be when i run my twincharged setup...i personally think twincharging will be the way to go...instant response and low end plus screaming top end
Dan
Dan
Dan
Dan
your car is going to be hard as hell to launch on street tires dan, but god damn that thing is gonna be a beast. how far are you going suspension and drivetrain wise to keep traction? You should def. get a locker if you havent already thought about it or bought one.
Originally Posted by 8cd03gro
it's the size of the compressor if im not mistaken.
already int he plan, i placed my order on a gt30 bb today, so i have made one step next is my intake manifold, and exhaust nexta nice 2.5 ionch air to air intercooler, man so many parts, right now to run efficiently at about 17 pound si should be around 2500 built and installed, pistons is my plan for the winter
Originally Posted by roccityroller
low compression pistons and beefier rods are your friends
why go low compression for race purposes?????? high compression makes more power per psi, it s just not as safe knocking wise.
Changing your ignition timing would help the knocking problem as well
Originally Posted by 2K5SS/SC?
Your crazy bro! That's a damn big turbo, but good luck with it!
yea unless you are going with diff internals you aren't really going to be able to justify that turbo. A smaller turbo will spool faster and still meet your boost requirements unless you are redoing your internals and running massive boost of course!
Lol you and your GT28...
A certain turbo wont "give" you 20 PSI, its not like a pulley. Turbos have something called a wastegate that bleeds boost so you can run whatever boost youd like *and a boost controller hooks into the wastegate via a vacuum line and allows you to control the wastegate*
Originally Posted by StinkBOMB
So what turbo would give me around 20psi of boost?
are you looking for the fastest et's you can possibly get (what et's do you want if so)? or are you looking for response and autox type power that is always there and powerful, but not quite just drag power? what exactly is your perfect setup? this would make helping you decide alot easier.
I just want a turbo that will give me around 20psi of boost and has little lag. I don't want to have full on instantaneous power like I do with the S/C, the tires just won't stick. Something to have a nice low 13 second daily driver is all.
Think...do you want a turbo that will be at 20 PSI at 5 grand or a turbo that can reach 15 PSI and continue to climb at 3 grand? Key is you want the most useable power, not necessarily the more peaking power.
Hopefully that makes things a bit more clearer.
hmmmm... you aren't going to have the instantaneous power of a roots style blower with any turbo setup really, until you get into extremely high-tech tt or single turbo systems. low 13's could be done by most of the garrett 28 series turbos. you may actually want to go to a 30 if you want a little lag so you dont break the tires loose so easily. Really, just dont go too huge. i would actually reccomend doing this- there is a greddy dual stage boost control system that can be used on the profec a or profec b and some of their other boost controllers. Now, greddy sells a steering wheel mounded switch that lets you switch between high and low boost. This would be a very good idea if you want to go with a faster spooling, smaller sized turbo because you can be set at low boost thru first gear and switch to high starting in second or whenever you want, so it is easier to launch, but you will have that extra power.
