Tvs
Old Mar 26, 2009 | 11:06 AM
Scott.Florschuetz's Avatar
Tvs
Ive been looking around for some numbers from the TVS and if it is worth it or not. I plan on doing
TVS
60lb Injectors
Dual pass Endplate
Option B
2.8 Pulley
Hahn header
LS4 throttle body
Rotated mounts
Exedy Clutch Kit
What can i look at HP wise? over 300?
Old Mar 26, 2009 | 11:13 AM
ShortStack's Avatar
Dont think there is a 2.8 pulley for the TVS... Unless you want to upgrade your fuel system beyond 60s.
Yea youll be over 300hp.. but youll need a good tune for it.
Old Mar 26, 2009 | 11:16 AM
Mnatvyc1223's Avatar
TVS
60lb Injectors
Dual pass Endplate
Option B
2.8 Pulley
Hahn header
LS4 throttle body
Rotated mounts
Exedy Clutch Kit
u might wanna try the LS4 TB with the spacer on ur Heaton for now, i know they are a bit touchy, you might not like how it feels.
but overall MODS arent shyte without the proper tune, find a reputable member in ur area with HPTuners.
Old Mar 26, 2009 | 11:20 AM
ShortStack's Avatar
You can tune out the touchyness by raising the Scalar Area in HPtuners.
I would strongly recommend the ls4 tb with the TVS though.
The tune makes or breaks.
Old Mar 26, 2009 | 12:35 PM
Rodimus_Prime's Avatar
The LS4 is quite touchy, its not for everyone
Old Mar 26, 2009 | 03:10 PM
I dont mind the fact of the TB being Touchy, ive read alot on the TB Swap. Im just curious as to how the numbers are for the TVS. As far as the 2.8 pulley OTT sells a wide array of TVS pulleys for $55 it comes with a 80mm.....(im not sure what that equals to) And for the tune im going to get a base TVS tune sent to me (i have hptuners) and play with it from there. Im just wondering the overall possibilities on numbers with the TVS and if it is worth spending the money on it vs a turbo swap.
Old Mar 26, 2009 | 03:15 PM
SS/SCking's Avatar
Yep it worth it.. Look in to the return style fuel system from ottp
Old Mar 26, 2009 | 03:32 PM
dont have that much more money right now...LOL but i read up on it and i think i might go with the 72's. i forgot to add above i have a 3inch custom magnaflow exhaust and i will have a 3 inch intake with the ZZP 3 inch MAF. not sure on what pulleys to get now heres my choices
64mm / 2.5" ~ 27.5 psi
70mm / 2.75" ~ 25 psi
75mm / 2.95" ~ 22.5 psi
80mm / 3.15" ~ 20 psi
85mm / 3.35" ~ 17.5 psi
89mm / 3.5" ~15psi
im just trying to see what would be best for my stock internals right now...(build to come)
Old Mar 26, 2009 | 03:51 PM
SS/SCking's Avatar
im goin with the 75mm
Old Mar 26, 2009 | 03:53 PM
rnjmur's Avatar
89mm / 3.5" ~15psi
Probably not a good idea to go smaller than the 80mm without doing some major engine overhaul.
Old Mar 26, 2009 | 03:59 PM
So from the people with the TVS would you reccomend the TVS setupover a custom turbo built setup? i can do them for same price. Turbo setup would include
-T3/T04E 50 trim .63 a/r Stage 3 wheel Turbo (Slowboyracing)
-Vulcan Turbo Maniold
-Tial 38mm Wastegate With Open Dump Pipe
-Tial 50mm Blowoff Valve
-Turbosmart Boost-tee MBC
-Hahn Intake Manifold
-CX Front Mount Intercooler 27" x 10" x 3"
-Custom Turbo Charge Pipe (2 1/2" hot side, 3" cold side - welded in Maf bung & BOV bung)
-Custom Catless Downpipe
-Rebel S/C Pulley delete kit
-Oil Lines & fittings
-K & N Air Filter
-High Quality t-bolt clamps
-High Quality 4-ply couplers
-Comes with bolts & hardware
-misc vacuum lines
-Base hpt Tune file for 60lb injectors to get you started (You will need it tweaked but it's a start)
Old Mar 26, 2009 | 04:40 PM
a 75mm will not work properly without a ported head, i actually made less power with it
Old Mar 26, 2009 | 05:09 PM
Well then im going to go with the straight turbo setup then.........sounds a little bit easier to tune and alot more potential.
Old Apr 13, 2009 | 10:44 PM
SS/SC Crazer's Avatar
ok, here is my question, i was gonna go with a ported and polished M62 with a 2.5" pulley, 60lb injectors, cooling mods, return fuel system, cai, and full exhaust, but now i am going to go with the Harrop, what is the smallest pulley you can run with stock internals????
Old Apr 13, 2009 | 10:51 PM
Pyros777's Avatar
I had considered 72lb'ers as well, but heard bad things about the idle due to 60s being the max that are fully recognizable by the PCM.
60's will be more than sufficient for power levels between 300--350. Add meth and you can go higher without having to go to larger injectors.
As far as the smallest pulley on stock internals, there is really no established limit. Not that I've come across anyway. Other things will hold you back before you have to upgrade your internals (such as the fuel system).
Keep in mind there are turbo conversion LSJ cobalts (Paul) with over 440whp on 100% stock internals. It's really a non issue as long as the tuning is there.
Old Apr 14, 2009 | 12:16 AM
ok so what is the smallest pulley you would run with the set up listed above???? with the Harrop that is! i want the most power i can get with this set up!
Old Apr 14, 2009 | 12:28 AM
80mm is as small as you should go
Old Apr 15, 2009 | 12:54 PM
ebristol's Avatar
Your an idiot. You post in almost every LSJ thread and you don't have a clue what you are talking about. Stop posting and start reading...
You can get any size TVS pulley you want.
http://smoothflowpulleys.com/Stage2.html
The LS4 TB is very touchy. I have used one and I will not put one on my TVS.
This is the most important part of deciding what pulley to go with.
Old Apr 15, 2009 | 06:45 PM
i got people telling me don't go any lower than 80mm with out head work, then i got other people i can use a 2.5" pulley with a damn good tune and c big gains, hmm.... still don't know what to do, i guess i'll start with the 80 mm and play around from there!
Old Apr 15, 2009 | 06:50 PM
Pyros777's Avatar
Yeah obviously you dont want to start out with the smallest pulley possible. Thats just asking for trouble!
Old Apr 15, 2009 | 07:43 PM
Omnigear's Avatar
ask lsjwannabe
^_^
he has it in his balt
Old Apr 15, 2009 | 07:58 PM
Darkmanx's Avatar
Yawn...
Old Apr 15, 2009 | 08:51 PM
i know, ive been pm'ing him, he actually lives right down the street from me, lol
Old Apr 16, 2009 | 11:06 AM
christ you had a whole thread of our own asking that question, you gotta pollute someone elses with the SAME question? where the hell do we find these newbs now a days?
Old Apr 17, 2009 | 07:08 AM
ur right, didn't mean to go way off topic, im sorry, im gone!
