tvs blower help plz.
Old Jan 9, 2009 | 04:02 AM
wtpcobaltss's Avatar
Ok so i was doing some research on eatons new tvs blower. i watched a few redlines do some pulls and it seems to be a good investment...but what kinda of tune would i need. would it be possible to bolt on the tvs and use the gm stage 2 tune with 60s or would i need a hptuner or whatever. im very new to tuning and dont understand how to tune at all.
Old Jan 9, 2009 | 04:14 AM
steddy2112's Avatar
Search.
There was just a writeup on this.
IF you think there is an easy way to do this, or hope there is, don't even do it.
60s, a tune, and an aftermarket/cobra heat exchanger at a BARE minimum
Old Jan 9, 2009 | 04:33 AM
well i already have a cx heat exchanger. will the gm stage 2 tune work on this blower if running the same amount of boost that stage 2 would put out on the stock sc.
Old Jan 9, 2009 | 04:38 AM
Herndon_High_SS's Avatar
no. If you need to make this thread on whether or not you should get a tvs then you are not ready. Read up before you make a thread.
Old Jan 9, 2009 | 04:57 AM
ViLerocker's Avatar
There's plenty of info on this posted on this site for this. Get aquainted with the search function and it'll do you a lot of good with this subject. Find threads written by Wicked2005SS (I believe that's his name on here), he did a whole writeup on the Harrop TVS system, and I got a lot of good info out of it. But to directly answer your question, the Stage 2 tune will not work the the Harrop TVS and niether will the 42lb/hr injectors that come with it. As stated before me, you need to do some serious research before looking into the TVS. It's not something to jump into with no previous knowledge because your dealer isn't going to necessarily going to be able to help with it, only a tuner who has experience with it will if something isn't going right. You'll need 60lb injectors, intake, header/dp/exaust, and a H/E for starters, and a tuner who knows how to work with it. Not to mention save up in case the clutch does go, it might, it might not. I'm not an expert on this at all, but I've done my own research. The TVS can be a beast if you know what you're doing with it.
Old Jan 9, 2009 | 05:22 AM
Deathscythe's Avatar
Guys, relax! He's only got 9 posts and probably doesn't even understand how to navigate the site yet.
Thanks for joining the site first off.
Now, for your question, what many have said is right, the 42's with the stage 2 tune won't work. Your going to need a set of 60's and a good tune to get it to work. If you get a custom tune with the 60's before you install the tvs then it won't be that hard to get a base tune down. I had a 2.85 pulley and 60's on mine with a modified stage 2 tune and the changes needed were very minor. My car started right up and ran with any big issues from the previous tune on the car made for the m62. Like steddy 2112 said support mods are a must to get the most out of it. The swap is pretty straight forward, minus the front bolts being hard to reach, the tuning is going to be the problem, depending on how far you've gone with the m62.
Old Jan 9, 2009 | 05:28 AM
PinaSS's Avatar
Am pretty sure someone will help you out or the search bottom will help you out to. But definitely you would need to find a good tuner for your project and some corresponding mods such as intake, header/dp, catback and injectors. Good luck though and welcome to the site.
Old Jan 9, 2009 | 10:16 AM
lsjwannabe's Avatar
Shoot me a pm with any questions you have its a little easier that way
Old Jan 9, 2009 | 01:26 PM
awesome thanks
Old Jan 10, 2009 | 02:16 PM
cahtr6's Avatar
Hey I have a question I just bought my TVS and am in the process of gathering parts to do the install. I have most everything but finding a ls4 throttle body seems difficult. I noticed BBK makes an aftermarket ls4 throttle body rated at 80mm is that too big? Does anyone know what the stock ls4 T/B is rated?
Old Jan 10, 2009 | 02:28 PM
lsjwannabe's Avatar
stock ls4 is 76mm iirc, the ls4 tb is not a must and the tvs can be ran without it. You can just search in the mean time for one as it is a 15 mine job to change and then go tune.
Old Jan 10, 2009 | 02:32 PM
06superchargedbalt's Avatar
X2, that's what this forum is for and he's in the right section...c'mon we're a community.
Old Jan 10, 2009 | 04:13 PM
cahtr6's Avatar
Thanks I would rather have one on and get the whole thing done at once. I didn't realize it was so hard to find a stock one.
Old Jan 10, 2009 | 04:23 PM
ViLerocker's Avatar
I don't think anyone was jumping on him about it. One person told him to do some more research, and I told him to get aquainted with the "search", because that's the easiest way to find more good info since there's a lot of good stuff up already :
Old Jan 10, 2009 | 04:33 PM
lsjwannabe's Avatar
Search local junk yards or if it really comes down to it im sure you can get one from gm.
Old Jan 13, 2009 | 10:17 PM
cahtr6's Avatar
I finally found a brand new one came with intake manifold injectors and throttle body brand new for $175 now I just need to sell intake and injectors.
Old Jan 13, 2009 | 11:17 PM
StageII07's Avatar
I was acctualy thinking about getting a TVS myself..Would anyone care to write down a list of parts to SUPPORT the TVS i dont wanna go blowing up my car and stuff but i would alost like to get around 320FWHP..if possable..but i think thats like on the razors edge of the TVS..pushing it muhc?
Old Jan 13, 2009 | 11:19 PM
ShortStack's Avatar
Heat Exchanger.
Meth.
60s
Tune
LS4 Throttle Body (not needed, but would be nice)
3" Intake (also, not needed, would be nice)
Dual Pass + Option B
Old Jan 13, 2009 | 11:21 PM
StageII07's Avatar
Originally Posted by ShortStack
Heat Exchanger.
Meth.
60s
Tune
I have an Injen CAI idk if its 3'' and dont our cars come stock w.the dual pass?
Old Jan 13, 2009 | 11:24 PM
ShortStack's Avatar
No... Injen is 2.5
And no... our cars come with Quad-Pass
Old Jan 13, 2009 | 11:25 PM
StageII07's Avatar
No... Injen is 2.5
okay well its not needed anyway but
and hmm quad pass..for some reson that sounds better then dual pass.haha
thats honestly not much for the blower..a few things and thats it..it can run off stock exhaust and what not
Old Jan 13, 2009 | 11:29 PM
ShortStack's Avatar
Lol.. well.. actually.. yes.. it is needed..
To run anything efficient on the TVS you need ALLLL the cooling you can get.. period.
Well, i was thinking you were just talking about the motor, sorry..
Id go with long tube headers to get power throughout the entire rpm range, not just up top.
Id do everything 3" from headers on back.
And also, the longer the coolant is touching the enging (4 times), the hotter it will get..
If it only passes that area twice (reducing the amount of time it is near the engine) will net cooler temps.
Last edited by ShortStack; Jan 13, 2009 at 11:29 PM. Reason: Automerged Doublepost
Old Jan 13, 2009 | 11:32 PM
StageII07's Avatar
Oh alright soo..its more then i thought..lol..haha ehh..bye bye warrentyy
ahh i see i didnt know that..lol
ShortStack's Avatar
Lol.. switching the supercharger will void warranty anyway, along with the injectors... um.. and just about everything else haha..
Old Jan 13, 2009 | 11:37 PM
StageII07's Avatar
lol pretty much..ehh..idk..i geuss i got a while to prep for it..and maybe bye then my warrenty will be done..soo ill work small..new 3'' intake heads and downpipe,full cat exhaust. get the meth kit. Torque dampner and dualpass new brakesand clutch too..and then the blowerrrr.
