TVS dyno #'s
Old Jun 6, 2009 | 11:26 PM
Tennpenn83's Avatar
TVS dyno #'s
There was a get together in Columbus this afternoon for a local car club, and they were generous enough to bring a dynopack portable dyno for all the cars. Best thing, it was free!
There was no tuning allowed while on the dyno, but I was able to make a log of my 3 pulls on the HPT scanner.
The following are the "need to know" facts :
K&N Typhoon CAI
LS4 tb
TVS with stock 3.1" pulley
79 lb/hr injectors
NGK BKR7E's gapped at .035"
Diamond Forged pistons (9.5:1 no coatings)
Cometic Head gasket
ARP head studs
GM dual-pass intercooler endplate with Opt B
CX racing dual pass heat exchanger
ZZP mid-length header/cat-less 3" downpipe/ full 3" exhaust
(mostly) my tuning with HPT
And here's what happened on the dyno :
Ambient temperature 87*
cars sitting in line for a while, heat-soaking before actually dyno-ing
finally getting to the dyno was a get-in, hook up, 3 pulls, wheels back on, get out so the next guy can go process. all in all took about 6 minutes
dynapack "hub" dyno (where they take your wheels off and attach adapters to slot into tq-reading "machines")
3 back-to-back dyno pulls with no cool down
my afr read anywhere from 11.2-11.4
17-18* timing
iat2's after a wot pull hit in the 155-160 range
dyno guy only revved to 6500, even though i told him i had the rev limiter set to 7200.
And here's the dyno sheet :
You can see I need to work on the torque down low. You can also see the graph cuts off at 6500 and is still continuing on its way up.
My thoughts on today's events... I am happy considering the conditions and the conservative tune. I need to work more on dialing in the MAF as my tune is mostly MAF based. I hit 284.8 whp with conservative timing and very conservative A/F ratio. I do not consider myself to be an expert tuner by any means, but I do know that there is lots of room to work with. I can easily hit over 300whp with some tuning, and some cooldown time before and between runs.
For those of you with HPT that would like to see my logs of the dyno runs, PM me.
Any thoughts?
And Zoomer - stay out of my thread. I know I can make more power with a turbo.
Old Jun 6, 2009 | 11:33 PM
WSFrazier's Avatar
I heard from someone that you TQ'd your rod bolts wrong, and are now hearing a knocking sound from the block.
Old Jun 6, 2009 | 11:39 PM
damien's Avatar
Easy mistake I almost made.
Old Jun 6, 2009 | 11:42 PM
MarqueDo7BabyBalt's Avatar
nice numbers man...
Old Jun 6, 2009 | 11:47 PM
Tennpenn83's Avatar
i am hearing the tensioner as it's going bad. the rod cap bolts are probably over tq'd, but ok. but me being as paranoid as i am, i'll probably replace them eventually with the a1 technologies set.
i am not hearing anything besides the timing chain tensioner
good to see you too ws...
Originally Posted by MarqueDo7BabyBalt
nice numbers man...
thank you
Old Jun 7, 2009 | 11:28 AM
Tennpenn83's Avatar
Bump for some pics :
mud crutch's cobalt :
my friend pete's camaro :
...with an sts turbo kit :
and a rich guy's bentley :
Old Jun 7, 2009 | 11:37 AM
lsjwannabe's Avatar
I see a pulley swap in your furture
Old Jun 7, 2009 | 11:59 AM
Tennpenn83's Avatar
plus a ported head... and valvesprings... and clutch... lol
want to dial in the maf a bit better and hit the 300 mark before i pulley down.
Old Jun 7, 2009 | 01:07 PM
Deathscythe's Avatar
it's not going to take much to get there. Press on slowly and safely.
Old Jun 7, 2009 | 02:37 PM
Maxim_X's Avatar
Nice numbers! Def some more in her.
Old Jun 7, 2009 | 03:13 PM
StevesBlack06's Avatar
if this is true replace them ASAP! thats bad news. i overtrqd mine and i sheared them at 6k and kaboom. very expensive mistake. please replace them asap. im using ARPs this time around. and i can see you makin over 300 easily.
Old Jun 7, 2009 | 11:43 PM
Tennpenn83's Avatar
yeah i'm looking right now at getting some from arp or a1 technologies and will be replacing them as soon as i can. but again, i am not hearing any sound coming from the engine except for the timing chain tensioner which is going bad
i think 300whp and then some can be had rather easily, with some cooldown time and of course a better tune.
Old Jun 7, 2009 | 11:45 PM
Darkmanx's Avatar
wanna play soccer with that ls4 tb?
Old Jun 7, 2009 | 11:50 PM
Tennpenn83's Avatar
only if i can score on you
Old Jun 7, 2009 | 11:52 PM
Darkmanx's Avatar
Did you just hit on me? wtf is up with that
Old Jun 8, 2009 | 12:46 AM
coopn8r's Avatar
Its how jordan rolls.
I had 0 knock on my engine after overtorquing the rod bolts until kaboom.
Be careful so I don't have to drop the, "I told you so."
Old Jun 8, 2009 | 10:37 AM
Tennpenn83's Avatar
only if you think you thought that i thought i wanted to think that once
always careful, always paranoid.
Old Jun 8, 2009 | 10:48 AM
freakta's Avatar
on aanother note, how much boost are you getting
lets see 400hp
Old Jun 8, 2009 | 11:07 AM
coopn8r's Avatar
lets see 400hp
He wont see 400whp without some Porting of the Cylinder Head, Meth and Race Gas..
Old Jun 8, 2009 | 11:38 AM
ralliartist's Avatar
I like how WSFrazer comes in and just hates. God damn your iconic.
Old Jun 8, 2009 | 01:07 PM
Zooomer's Avatar
Supporting Vendor
284.8, nice job.
Old Jun 8, 2009 | 07:23 PM
Tennpenn83's Avatar
lets see 400hp
like coop said, ported head, meth is a must. i will hopefully be picking up some meth here soon, and the p&p head/valvesprings hopefully by august. then i can pulley down on the tvs and run some race gas and whatnot. we'll see how it goes.
most of what's on the tune is my own doing, with a little help from some others. i do not claim to be an expert at all at tuning, so i should probably become good friends with someone that is...
Originally Posted by Zooomer
284.8, nice job.
thank you. there is plenty of room to work with on the tune to shoot me well past 300
Old Jun 8, 2009 | 08:14 PM
WickedSS2005's Avatar
WTF? Zooomer being nice in a TVS thread... I just felt a chill. Props
So, you come to Dayton and can't work it out to let me play with your blower. Ass
Old Jun 8, 2009 | 08:23 PM
"let me play with your blower" so many ways that can go.
Old Jun 8, 2009 | 08:24 PM
Tennpenn83's Avatar
so i come to dayton and you have to work all day? Ass...
lol... you're an ass too...
