tvs guy's
Old Dec 11, 2010 | 02:01 PM
  #51
InfraRedline's Avatar
Originally Posted by Josh@ottp
The bolts shearing off can only occur if the fastener is torqued past its rating. So those cases were improper install somewhere along the line.
We have had 3 other cases of nicks and gouges on the rotors. Harrop chose not to warranty them as something has obviously been sucked up.
Yeah I agree installer error for the most part. I was just trying to make a point to the person that said they are problematic that that is the one and only complaint I have ever heard, nothing serious.
Old Dec 11, 2010 | 03:18 PM
  #52
mrbelvedere's Avatar
there are a couple of guys on another forum that have had bearing failures but with how many that are in use your going to get a a few bad units
Old Dec 12, 2010 | 10:10 AM
  #53
freakta's Avatar
i had bearing failure on my m62 ( why i now have a tvs )
Old Dec 12, 2010 | 10:57 AM
  #54
cli3e0339384398jk's Avatar
Originally Posted by freakta
^^^ the tvs made a huge difference. i dont know who says it doesnt. but the problem is no one is going down on the pulleys like they did with the m62.
try it out put on a 2.6 on the m62 with all the right supporting mods and then do a 2.6 on the tvs and see what it does with all the right supporting mods
i wasnt talking about a tvs, i was talking about ls4 throttle body, im running a tvs and a 2.7
Old Dec 12, 2010 | 11:00 AM
  #55
most of the people that have instsaled the ls4 havent took the time to tune or play with the settings in hpt mine is touchy and i had to relearn how to drive my car but the bottom and mid it gave me was worth the trade off not that i have it on the tvs it isent as touchy
ok, well its a cheap part i will buy and try out for myself
Old Dec 12, 2010 | 01:01 PM
  #56
freakta's Avatar
my bad... how do you like the 2.7? im waiting for delivery of my 2.5
Old Dec 12, 2010 | 02:07 PM
  #57
You guys and your damn man pulleys lol
Old Dec 12, 2010 | 03:15 PM
  #58
crazywhiteboy89's Avatar
You were lied to. Harrop makes superchargers for OEM's around the world. The reason they don't carry it is because dealer price is $2150 to everyone. The only way to get it cheaper is to buy from us. They simply can't compete.
hey josh i pm u i looking to get a tvs get back to me
Old Dec 12, 2010 | 08:29 PM
  #59
i like it, it brought back some low end torque, im still undecided on if i will keep it or not, it definatly needs a slight roll back on timing. ( can only get 23/24 into it without knock). 2.5 is brave, thats brave 27+psi haha
Old Dec 12, 2010 | 09:48 PM
  #60
Bluelightning's Avatar
Got Bewst?
Whos running meth with their TVS? What kind of mixture are you running?
Old Dec 12, 2010 | 10:20 PM
  #61
i am, 100% meth 7gph
Old Dec 13, 2010 | 05:42 AM
  #62
freakta's Avatar
im running a mix for no reason... ill prob be running 100% soon
Old Dec 13, 2010 | 02:23 PM
  #63
Got Bewst?
You're guys temps aren't crazy high with no water? I know a TVS is much more efficent than the M62 but what kind of temps do you guys see after a pull?
Old Dec 13, 2010 | 04:50 PM
  #64
Pyros777's Avatar
I see 160--165 tops after a couple pulls in 95F+ hot/humid weather, but it falls right back down. On a nice day it doesn't go past 140 unless I really abuse it.
Old Dec 13, 2010 | 05:25 PM
  #65
SuperSport4's Avatar
^^^ isnt that pretty high iat's nfor a 3.1pulley??
Old Dec 13, 2010 | 05:28 PM
  #66
Pyros777's Avatar
2.9, and that is peak IAT2. It drops off very quickly.
*those are pre-griffin numbers. I haven't datalogged my own car in months. lol
Old Dec 13, 2010 | 06:47 PM
  #67
no meth my temps usually get around 135-140 after a 2-3 pull on a 70 degree day. Saw 160 once after a 30-130 pull on a 80 degree day with nothing but an incorrectly plumbed cobra h/e.
Old Dec 13, 2010 | 10:01 PM
  #68
on a 2.9 i would see 145-150 after a pull, hasnt seemed to change much on the 2.7 on the tvs, but it was colder out by the time i got it installed, i have it so the car wont pull timing unless 150 is reached as soon as i go wot it starts cooling usually at the track as it heat soaks when im waiting in line
Old Dec 13, 2010 | 10:19 PM
  #69
freakta's Avatar
with 2.8 im running a few degrees below ambient after a few runs with meth. without it im only 10 or so degrees above
Old Dec 13, 2010 | 10:54 PM
  #70
Got Bewst?
Wow good to know. I plan on going TVS just unsure when. If the right price on one came up i'd jump on it. Unfortunatly up here in Canada we don't have E85 so i gotta stick with meth in the mean time.
Old Dec 13, 2010 | 11:07 PM
  #71
meth is fine, just go with as large of nozzle you can without issues and push your cars timing, run 100% for octane value
Old Dec 14, 2010 | 12:16 AM
  #72
Yeah if you cant run E85 a 7gph or so spraying 100% meth will be the next best thing.
Old Dec 14, 2010 | 03:52 PM
  #73
rcorona8's Avatar
Are you on stock internals? what about pnp head?
Old Dec 14, 2010 | 11:10 PM
  #74
Yep on stock internals for now. Have a ported head going on over this winter though!
Old Dec 15, 2010 | 09:03 AM
  #75
brutus.nova's Avatar
Running no watermeth and IAT's dont go above 120 with a TVS 2.9 and to the E85 M62 guy I am making 310/267... GOD I need to just suck it up and buy the smaller nozzles.
