Tvs Install Help
Old Mar 10, 2009 | 04:08 PM
crt013189's Avatar
Tvs Install Help
Does anybody have a pic of the map sensor how it has to be modified i searched and cant find it for the life of me i need it so i can install the harrop ASAP
Old Mar 10, 2009 | 04:13 PM
thought's Avatar
I recall fast98 mentioning you need to rotate it.....Might be a good idea to ask OTTP.
Old Mar 10, 2009 | 04:14 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You can either rotate it... or you can Dremel it.
Old Mar 10, 2009 | 05:02 PM
crt013189's Avatar
i know i need to rotate it and dremel it does anyone have a pic anywhere
Old Mar 10, 2009 | 05:06 PM
lsjwannabe's Avatar
Old Mar 10, 2009 | 05:09 PM
crt013189's Avatar
sweet thanks do i still use the original bolt hole or the one that you notched out of there
Old Mar 10, 2009 | 05:11 PM
lsjwannabe's Avatar
The orginal one works
Old Mar 10, 2009 | 07:52 PM
boostnss's Avatar
subscribed
Old Mar 10, 2009 | 08:03 PM
SS/SCking's Avatar
Thats an awesome thing to know.....
Old Mar 10, 2009 | 09:34 PM
06 pursuit gt's Avatar
thanks for posting that Sean! that will be useful in about a month.
Old Apr 23, 2009 | 09:20 PM
RooTBeeR's Avatar
sub'd
Old Apr 23, 2009 | 09:24 PM
MarqueDo7BabyBalt's Avatar
ha..after about a year of collecting parts right drew lol...jk hey we have the same last name haha
Old Apr 24, 2009 | 01:08 AM
RooTBeeR's Avatar
BULLSHIT! really? u a williams too? haha thats crazy man.
/end thread jack
Old Apr 24, 2009 | 05:40 AM
wheeldude1's Avatar
Not a MAP sensor
that is not the MAP sensor btw it is the air intake temperature sensor, if you do take it out and modify it make sure it doesn't have any carbon built up on it as this can happen to cars who's AIT sensor has been relocated from the MAF sensor in which it usually is with other ecotec engines. they moved it off the MAF because the intake filter is so far away from the Intake manifold. so cars with short ram intakes may suffer this sensor getting blasted by intake backfire and blowby. It happened to mine.
Old Apr 24, 2009 | 09:51 AM
/end thread jack
yup...your my brother from another mother haha
/now end thread jack lol
Old Apr 24, 2009 | 03:07 PM
Rodimus_Prime's Avatar
its too bad they cant change the design a bit better to fit
Old Apr 24, 2009 | 03:15 PM
coopn8r's Avatar
They don't care about sensors :P They just design big ass ******* blowers to go fast
How did the install finally work out for you OP?
Old Jan 22, 2010 | 12:23 AM
Pyros777's Avatar
It is in fact a MAP sensor. It is a 2.5 bar Bosch TMAP. Serves as our IAT2 sensor. IAT1 is integrated into the MAF.
Old Jul 29, 2010 | 04:05 PM
csementuh's Avatar
Hate to bump an old thread.. but.. Does anyone know if simply rotating the MAP can lead to a vacuum leak? I rotated mine and I seem to be having a leak now that is causing wacky fuel trims and P0300 random cylinder misfires.
Here's the thread... https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/vacuum-leak-around-map-sensor-causing-misfires-help-223284/
I think I'm gonna pull the TVS off and dremel it...
Old Oct 1, 2010 | 09:04 PM
startingline05's Avatar
here i go bumping an old thread but can u only get these sensors from the dealership? i broke mine today trying to install the tvs before i saw how to modify it. so now i need a new one. i cracked mine half off but it looks like it still makes contact so i tried cranking the car anyways and all the car does is idle at 3000 the tries to die and does this over and over
Old Oct 1, 2010 | 09:12 PM
RooTBeeR's Avatar
GM Parts Direct: Your direct source for Genuine GM Parts
...oops. looks like their catalog is unavailable A.T.M.
so here ya go
http://www.partswebsite.com/gmpartsc...searchall=test
Old Oct 1, 2010 | 09:32 PM
well it turns out that when i called auto zone i called it the wrong thing, i asked for a maf and they told me they had the map sensor, so hopefully i can just go grap like 5 tomorrow just incase i screw more up lol
Old Oct 1, 2010 | 10:04 PM
RooTBeeR's Avatar
how much at auto zone?
Old Oct 1, 2010 | 11:32 PM
i think like 60 bucks or something, ill tell u for sure tomorrow after i get it
Old Oct 1, 2010 | 11:35 PM
RooTBeeR's Avatar
oh, damn...thats why mine is still cracked and installed haha...at least the crack is minor and above the o-ring
