TVS Install Question NOT MAP SENSOR RELATED
Old Sep 9, 2015 | 10:15 AM
RedLined's Avatar
Hey guys just installed my TVS this weekend and had an issue with the throttle body gasket. My original off of the m62 was way too thick to use so I installed the throttle body without it and sure enough I've got a vacuum leak. What has everyone else used? Just trim the gasket to fit? Also is there anywhere else people normally get vacuum leaks after installing a tvs?
Old Sep 9, 2015 | 11:09 AM
SunburstSS's Avatar
trim it down and, clean the surfaces and use some RTV High Heat Silicone for a perfect seal if you are still worried.
Old Sep 9, 2015 | 09:11 PM
mrbelvedere's Avatar
the tvs should have an o ring o it aready if not order one from ottp as it is different then m62
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Bohb
Sep 27, 2015 09:11 PM
jmelton327
Sep 26, 2015 10:04 PM
