tvs with meth problem
i have the snow performance meth kit and it worked perfect with the stock blower.but now with the tvs,when it sprays the car falls on its face above 5000 rpm's.hpt isnt showing anything wrong though, no miss and no knock. even the air fuel still looks good and its not pulling any timing.car runs perfect off the meth though.any idea wuts goin on.i dont know if it helps but the plugs are two stages colder and gapped at 35.and the meth sprays before the throttle body.boost is at 22-23 psi. i got the blower spacer with the holes tapped for meth but i would like to figure this problem out first.thanks for the help
What timing are you running now? And do you have settings for how much the output is for the pump to the supercharger? I was running a 7gph nozzle with a 50/50 mix. My timing went from 18* without meth, to 24* with the meth involved. Look into the timing. I don't think it's cold enough for you to have to worry about the temps outside.
the 2.5 exhaust will hold up his hp but not stumble his engine.
do you have the vacuum block inline thing so the car doesnt pull meth out the whole time you drive down the street?
i had that problem, sounds similar
mine are gapped at 0.032 with tvs, meth(7gph nozzle), timing as high as it can go, 60lb's, 3 inch exhaust.......and a bunch of other crap. I would give it a try, worst that can happen is it doesnt work. My car runs great
Yah, but we pulled a 1 degree back before I put the car away for the winter as I had not upgraded to 3 inch from downpipe back and was getting knock above 6900rpm. I got the exhaust all installed but ran out of time to re tune before the snow flew. Snow sucks. Next year.
I was already at a 3 inch downpipe it was after that I was stock exhaust, ( so I cut the 2.5 inch flange and had welded 3 inch installed in late fall- zzp 3 inch downpipe with 2.5 exit is what I had originally. There was a difference but weather was shitty do I never did get to play around with it a lot. Main reason I installed 3 inch was due to knock I was getting at top end due to restrictions in exhaust ( I had damage done to it from driving gravel roads so where it went to 2.25 over the axle was probably down to 1.75 restriction.)
