TVS Set-up Suggestions??
Hey guys,
I'm getting my TVS in like a week and I need the help of other TVS cobalts guys on here. I'm just trying to find the limitations of the stock fuel system. This will be my starting setup when I do the intial dyno tune. E85 is every where around me, taunting me, so I'm getting it.
80#s
E85
TVS (Stock Pulley (80mm I believe))
Stock fuel system
ZZP dp (w/cat, 2.5" in, 3.0" out)
Honed GMPP manifold
Vibrant 3" exhaust
Option B dual pass
K&N intake
What pulley can I drop to on this set-up?
What power can i expect with the stock pulley on the TVS?
If you look at my sig, it has my current mods. What gains with this TVS E85 set-up can you guys see over my current set-up?
I've arranged a dyno for a BEFORE / AFTER reading on my cobalt. I kinda like to see how close people can get to my soon coming dyno results.
80#s
E85
Stock fuel system
Honed GMPP manifold
Vibrant 3" exhaust
Option B dual pass
K&N intake
*raises hand* New pump and ZZP's BRFPS, w/o the return style option. Running a 2.7" pulley.
You will most likely not be able to drop pulleys below a 2.9 on the 80's on the stock fuel system on the summer blend. You MAY get away with the 2.8 but you may find yourself having to set your rev limiter lower than you'd like. I say throw a 2.9 on it and rev it out to 7400 until you can get a better fueling solution.
Its just that the tuning shop that I will have my car tuned at said that they have done a couple TVS E85 setups. They also said that I could see greater gain if I bought a return style fuel system because it would get rid of some limitations.
I never asked what pulley was on the ones that they tuned but I just have the stock pulley. I really do not want to keep the stock pulley on the TVS for long so I guess I am just trying to figure out what the smallest pulley I can go without a return style system, boost by reference and bigger pump. My car is just a daily driver and I need to keep it that way.
get a return style if your going under a 2.9/80's on e
moving that much air you don't wanna starve the last cylinder
return style promotes equal distribution and also helps the fuel run cooler instead of hanging around in the rail waiting to be used
Ok so I'll buy a return style fuel system if I go below 2.9 on the TVS.
When is it necessary to upgrade the fuel pumps for the cobalts? or it is something that can be overlooked.
I was reading that you could just increase the volts to the fuel pump and gain benefits that way kinda like the ZZP boost by reference system.
I've got TVS, 80's, ZZP brfpr, full exhaust with header, and cooling mods.... with a "safe" tune i'm at 312WHP 272WTQ
stock fuel pump, No E and No meth, no return style fuel system... Mines is an 07 tho
Also, size of exhaust and header?
Are you using a Griffin HE? I'm considering getting one
