Up to date Reflash
Up to date Reflash
I'm sure I saw a link to a GM site on here where you put in your VIN and it tells you if you have the right/latest reflash. I searched high and low, can't find it. Anyone know??
to who the stage 2 or me?
1G1AP18P177198069
thats my vin can u just see if i need an update
you seem to know what this **** means
I would def. go get the ECU recalibrated
blownss? lol come on i know you wanna
1G1AP18P177198069
Last edited by rockkrawler628; Mar 5, 2008 at 01:14 PM. Reason: Automerged Doublepost
why are you worrying about a reflash? Is there something wrong with your car? I know i've stated this before, but i have an 05 and i have one of the first stage 2's on the market and have had no problems and found no need for a reflash.
well actually... sometimes at idle my RPM's will shutter and raise and lower but when i tap the gas it'll stop
lol alright thanks
lol alright thanks
Last edited by rockkrawler628; Mar 5, 2008 at 01:16 PM. Reason: Automerged Doublepost
Just wanted to see, out of curiousity!!!
yeah i thought you were talking about me... cuz i don't have stage 2... i wanna get the **** with my car worked out tho... i've got problems with idleing sometimes and the fact that my evap system won't go through its parameters
https://www.cobaltss.net/forums/show...ighlight=flash
go to another dealer, the reflash fixes many 'potential' issues so just cus there are no issues with your car doesn't mean that none can happen. It isn't up to the dealership to decide when a reflash is needed. The only reason we knew about the updated flash is cus another member from phx was having issues and when I went to the master tech here at bill heard he found the updated flash and noticed all the things it fixes.
i've heard that reflash (at least one, not sure what else has been updated) updates were for issues with throwing lean codes causing the car to possibly run in limp mode and that the update just widened the parameters for that code.
So anything that shows up under the PCM section after i put my vin # in means it neads a new calibration?
Also can gm tech guys give my car a better tune if I talk to them about it?
