Update before i hit the sack
ok so i spent the last 7 hours working on the project
turns out i need to go buy an engine houst, i had a very good plan not to need one but the bottom end wont come off, so im gonna go pick one up tommorrow once the stores open.
I removed all 31 bolts inside the oil pan that i thought held the crank on and i was wrong, ive taken out ever bolt holding the lower section of the block on, still wont come off.....
so im going to throw the head back on, and the pulley tensioner so i can just pick the motor out of the car and drop her on the ground so i can pry the dam thing apart.
then i should be off to the machine shop i hope....
there isnt alot holding the motor in, just a torque brace, motor mount and the tranny.
Wish i had the extra cash to do the clutch now to..... damit all
oh yea and i did secure a digital camera for the reinstall, i am gonig to do a howto of installing a complete 2.0l LSJ engine into the SS, I would have done removal but its almost out.
now goodnight lol
now goodnight lol
Just grab a couple friends and a fence post and some chain. Our engine don't weigh ****! Just pluck it out by hand! Hell me a 3 friends had to do this for a small block in a Camaro when our buddies hoist died mid-swap and a 350 is a HELL of alot heavier then the ECO is.
Well either way best of luck to you bro!
LSX RWD S/C conversion
Just a heads up, the engine comes out from under the car not up out of the engine bay. The time to pull your engine is alot longer than you think. I had a mechanic friend help me and the process was almost 7 hours.
Originally Posted by Jackalope
So its impossible to pull it out from the top? That means you gotta drop the whole cradle out? Well that blows!
Now I will say that we took the tranny out at the same time and perhaps by not doing that it will come out on top easier. Of course I would suggest he wait to finish the project until he can do the clutch\flywheel or it is all coming apart again shortly after he puts it back together.
The engines in the 4th gen f-bodies are supposed to come out the bottom too , Ive pulled 6 out the top and found the wrong way to be easier than the right way if you dont have a hoist
If anyone has Microsoft Office and can open a .mdi file, I have GM's guide on how to remove the engine.
http://files.filefront.com/engineMDI.../fileinfo.html
all you have to do is unbolt the block from the tranny and remove the motor mount on the passenger side, my engine is hanging im having clearance issues i need about 1/4 an inch to pull it out, the flywheel is sticking in the bellhosuins, if you scoot the tranny back and inch and do what i did it comes out easy as ****
total i have about 15 hours in it, but most of that is doing pointless **** that could have been easily avoided and talking to random people showing up.
On another note,
just orderd a spec 2+ valentine 1 AEM Wideband 2 pod pillar bringing the grand total to $5300.00
On another note,
On another note,
On another note,
If ur tranny is still on that is the reason ur crank isnt coming out...your flywheel is directly bolted onto your crank shaft. Remove the trans and the flywheel and it should come off assuming u removed the connecting rods and timing chain stuff as well
Dan
Dan
