Upgrade Help
Old Dec 8, 2009 | 10:30 PM
MTS's Avatar
MTS
Upgrade Help
I just bought a 2007 SS/SC, it's already at stage 2 with intake exhaust etc. The pulley is a 3" and i wanted to go smaller. What else will i need to change or upgrade when I switch to a smaller pulley?
Old Dec 8, 2009 | 10:47 PM
Karlen89's Avatar
Pretty well limited without going to 60# injectors at the same time.
Old Dec 8, 2009 | 10:49 PM
ecotecturbo's Avatar
You will need to upgrade your fuel injectors to 60lbers if you want to get a smaller pulley and you have to retune for it.
Here is a stage kit with everything you need
http://www.zzperformance.com/cobalt_...1055&catid=143
Old Dec 8, 2009 | 10:53 PM
Karlen89's Avatar
Also, here's a great kit to look at as well.
http://www.ottperformance.com/store/...-2-Kit-4p6.htm
Cheers!
Old Dec 8, 2009 | 11:49 PM
MTS's Avatar
MTS
I've looked at both those packages. I'm already at the GM stage 2 though, so could i just get the injectors and pulley without buying that whole kit and just have a performance shop retune the PCM?
Old Dec 8, 2009 | 11:57 PM
Yes all you would need is new pulley with new hub 60s heat exhanger wiring harness for new injectors and a custom tune.
Old Dec 9, 2009 | 01:05 AM
sundevil07's Avatar
or you could run a 2.9 on the 42's and get a retune
Old Dec 9, 2009 | 07:30 PM
stonny9's Avatar
It has been proven that you can safetly run a 2.8 on the gms1 and gms2. I have seen it myself on numerious lsj's including mine and we beat on our cars everytime it is driven. yes the injectors will be maxed on the gm tunes but also remember that the gm tunes are set to run a little richer. Have never seen an injector break from the pcm requesting over 100% from the injector.
ran my car for 13,000 miles on stock tune/injectors with just the stg2 pulley/i/h/hp and idc was 152%(see sig) now that probably wasnt the safest but ran great.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
