Upgraded ARP timing bolt install
Old Jul 2, 2016 | 12:40 AM
cavfiredesire's Avatar
I am in the midst of installing my timing set and grabbed a set of the arp bolts from crate engine depot to use on it.
My question is in regards to the install.
What is the torque spec used for these, the same as stock or higher?
Do I have to do the typical arp install with lube under the flange of the bolt or not?
Many thanks..Phil
Old Jul 3, 2016 | 09:55 PM
mrbelvedere's Avatar
89in/lbs with a drop of Loctite don't over think it
Old Jul 9, 2016 | 01:46 AM
Tjolley's Avatar
ARP calls for 11 ftlbs
Old Jul 11, 2016 | 10:32 PM
^ pretty sure i went to 11 as I came across your post about it. But I think I accidentally used red....guess they aren't coming out haha.
Old Jul 11, 2016 | 10:51 PM
the 89in/lbs from gm was to keep from ripping the threads out of the block from over tightening 89in/lbs is more then enough
Old Jul 11, 2016 | 10:52 PM
you are supposed to use red and they will come back out its not permament
QuickSilver_SS
May 2, 2016 08:41 PM
ccsssc
Apr 30, 2016 02:09 PM
Haven07
Apr 20, 2016 10:13 AM
BrobaltSS
Apr 20, 2016 09:23 AM
Timnman
Apr 18, 2016 12:53 AM
