Upgraded radiator??
Gm to make the ls1 ss camaros like what I had I sold it
slower then the vet's They made them run hotter by useing a high temp thermistat after eather switching them out for a differnt stat or running the fans by a switch you can gain up to 10-20 HP thats not bad for a $5 switch.
So cooler motor no matter what will gain you some HP.
Lucky, i've watched my temps get up to 220 or so, but that was sitting in traffic. But its true, an upgraded radiator is in no way needed. The stock one on the car actually has a good sized surface area for heat transfer.
I agree. It seems that anyone who wanted the motor to run cooler just changed the temp at which the fans came on using HP Tuners. So it seems that the radiator is up to the task, but the computer just needs a little persuading.
