Upgrading to the 2.9
Old Dec 30, 2011 | 01:34 AM
duffman11's Avatar
Going down to a 2.9 pulley until the Cobalt is paid off
Was going to get 50# injectors
Get the GM S2 Belt
Do I need the modulary pully system?
Over sized pulley?
Adjustable tensioner.
I E-mailed ZZP and I never received an answer just talks about future set up and what I should buy then.
Old Dec 30, 2011 | 01:51 AM
SuperChargedMA's Avatar
Are you bone stock and you just want to pulpy down to 2.9?
Old Dec 30, 2011 | 01:55 AM
duffman11's Avatar
I have-
S3 H/E
Injen Intake
Header
Downpipe
GMPP exhaust.
Old Dec 30, 2011 | 02:10 AM
If you're buying from zzp, you need the modular pully system, the other two you do not need. You need a tune as well. New plugs arent a bad idea either. I'd suggest to just purchase a kit from zzp. Its not that expensive and the best idea yet. If you're still under warranty a GM certified stage 2 install isn't a horrible idea but a bit more expensive. Look around, some dealers do it for less.
Old Dec 30, 2011 | 08:45 AM
nhanson's Avatar
You need S2 belt and injectors. That's all
Old Dec 30, 2011 | 02:09 PM
sternerG85SC's Avatar
correct me if im wrong, if you have an oversized tensioner you use your stock pulley belt, if you use your stock tensioner you get a GM genuine stage 2 belt?
could you use a stage 2 belt and over sized pulley tensioner?
going to be runnin a zzp 2.9 pulley also
Old Dec 30, 2011 | 04:14 PM
SneakyMilo's Avatar
If you get the oversize tensioner you use your stock belt. Note that the "stage 2" belt that ZZP gives you is a piece of crap. I only got about 6K miles out of mine before it started falling apart (I am not the only one to experience this). I highly recommend skipping this and buying a real GM Stage 2 belt.
Old Dec 30, 2011 | 06:39 PM
i got the over sized tensioner from ZZP because what i heard about their belts fallin apart. was going to get a genuine stage 2 belt... but if i dont need it screw it. thanks for clarifying that up for me
Old Dec 30, 2011 | 06:43 PM
SlowCobaltSS's Avatar
Do u have the part number for the gm stage 2 belt?
Old Dec 30, 2011 | 06:49 PM
jgarciarivera's Avatar
Cobalt Stage 2 Belt 12597993
Chevycobaltss3's Avatar
50s are ok but 60s will let you have more leeway...
Old Dec 30, 2011 | 06:52 PM
thx.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
OPCrer
Sep 27, 2015 08:11 PM
