Upgrading LSJ
Old Jan 29, 2011 | 07:05 PM
ChrisR1S's Avatar
Talking Upgrading LSJ
Hey guys! Been stalking the forums since i got my car almost 2yrs ago, figure I'll finally make a post. Here's the deal:
My 06 SS/SC is bone stock performance wise other than an Injen CAI. I've been happy with it but its finally time for some more serious modding
Here's the plan so far, let me know what you guys think. Just wanna make sure I get everything I need and don't leave anything out. Assuming all goes well the purchases should be made within the week!
---ZZP stage3
-Oversized Tensioner
-S3 Heat Exchanger
-2.7" pulley
-80lb injectors
-Gas tune
---ZZP 3" Catless Downpipe
-bung for wideband(will plug it untill I get dual interceptors)
---ZZP Dual pass endplate
---Option B
-want to make my own kit but i dont know where to locally find the little reducer piece that slips into the hose???
---BadMab LSJ Header
Then after I get everything taken care of and get the Interceptors I'm thinking of maybe getting in touch with Bennybooster(ithink thats his username) and seeing if he could tune my car
Thanks for all input guys
Old Jan 29, 2011 | 07:09 PM
Phyrric's Avatar
Looks good, I'd strongly recommend getting the Catted DP, I have the ZZP 3in catted dp and the ZZP 3in exhaust with magnaflow muffler and resonator and I get the occasional rasp that sounds like ass, I couldn't imagine how it would be with one or more of those things not there.
And I'm assuming your going to get a cat-back along with whats listed
And I wish I had your self control to drive a car for two years and keep it stock, I'm usually shopping for the next part right after I order one
Old Jan 29, 2011 | 07:14 PM
ChrisR1S's Avatar
Actually I was going to leave the stock catback for now as I've read of others doing about the same exhaust setup without issues and without too much rasp.. I just don't want to keep going through cats with a modded engine. That gets expensive quick
And yeah it takes some serious willpower to not mod this car! Its my DD so I do most of my modding on my Jeep and my V8 Ranger
07BoostedG5's Avatar
Originally Posted by Phyrric
magnaflow muffler
thats why theres rasp, get a dynomax turbo muffler
Old Jan 29, 2011 | 07:25 PM
denlou's Avatar
If you want to get your moneys worth out of your mods, you should be thinking about a bigger exhaust so you don't have to retard so much timing.
Old Jan 29, 2011 | 07:27 PM
ecot3c inside's Avatar
I have a flowmaster muffler,
Old Jan 29, 2011 | 07:32 PM
RooTBeeR's Avatar
Originally Posted by ChrisR1S
---ZZP stage3
-S3 Heat Exchanger................dont bother with that h/e, get the griffin in the first place and be done with it if you can afford it
-2.7" pulley
-80lb injectors................your good there, wont run out of injector(i was pushing ~20psi on 60#'s upto 7200rpm and was almost maxed out)
-Gas tune
---Option B
-want to make my own kit but i dont know where to locally find the little reducer piece that slips into the hose???..............you can make your own pretty easy, 1/4" dia. wood/plastic dowel and drill an .040" hole in it or 1/16" bit if
you cant get the .040"
the rest of it will work, exhaust is pretty much preference. obv. some setups are better than others, but do whats in your price range. 1.75" primaries with a 3" collecter for the header is good, and a 3" dp with a 2.5" exit(if your planning not to touch the stock catback)
Old Jan 29, 2011 | 07:34 PM
ChrisR1S's Avatar
If I need to do it now, I think I would do the 2.5" kit from mandrelbendsexhaust with a good resonator and I'd experiment with mufflers..NO FARTCAN...Maybe try one of the stainless Borla muffles that came off of my buddys SVT Cobra, it was decently quiet on his car which was catless.
Old Jan 29, 2011 | 07:37 PM
denlou's Avatar
That's what I would do, you COULD use the stock exhaust but you're just not going to get the full potential.
Old Jan 29, 2011 | 07:39 PM
ChrisR1S's Avatar
Is the Griffin HE you're talking about the expensive($550) one on OTTPs site? It's a little out of my price range right now.
And thanks for the advice about the wooden dowel. No issues with it falling apart over time?
Old Jan 29, 2011 | 07:41 PM
RooTBeeR's Avatar
shouldnt have a problem, but if your worried about the wood get derlin or a plastic like that
Old Jan 29, 2011 | 07:49 PM
ChrisR1S's Avatar
Thanks man, ill look into that. Figure I'm better going the DIY route on this because IMO the Option B kit is way overpriced for what you get. Heck one kit i saw even had plastic T's. I can get the reservoir for like $20 then the hoses and brass fittings should be about another $20. $40>$110
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 28, 2015 12:51 PM
