Vaccum leak testing.............
I've been hearing a hissing noise and I have been getting code p0171 , and I believe its a vaccum leak somewhere... How can I test it.... ? Thanks
My mom has a smoke machine she puts out her house on halloween....I'm gonna see if I can use it... Lol
Just hope its not a cracked intake mani :'(
Last edited by turbosmart4; Jan 18, 2013 at 08:56 AM. Reason: Automerged Doublepost
GDS
So it will rev once it gets in the leak...? will it go past 7k rpms??? Jk jk I have to do it asap... If its leaking around there does it mean my injector rings are bad or head gasket?
If you're spraying right into where the injector seals are then it's the orings that are bad. If you don't find a leak through there spray on all the opening areas of the manifold also
Cobalt ss 06 100k miles for sale
Runs like new
Tc rims with lots of meat on tires
Professionally smooth and painted dash and trim
Smoked lights
New catalyc converter
New power steering assembly
Ttr trans mounts
Wrapped roof
15k obo or trade for an escalade
Runs like new
Smoked lights
Ttr trans mounts
Wrapped roof
Boost leak test with soapy water. That would be the preferred method. DO NOT use carb cleaner on a hot engine, lol, unless you like potential fires. Crack open the propane and run it across the potential leak areas. The rpm jump won't be a lot, just enough to compensate the unmetered air entering the leaking area.
I can definately hear the buzzing sound a little louder.......... And didn't see any leaks around the iinjectors ..but it was at night... Hope I get off work early so I can start looking into the intake many area.......
and I used soapy water
Last edited by turbosmart4; Jan 19, 2013 at 08:13 AM. Reason: Automerged Doublepost
Did you spray tb cleaner around the injectors with the car running? You are not going to be able to see a leak with your eyes, just by looking at the injectors.
I hear a buzzy hissy sound when im driving too. Idk whats leaking i replaced a few hoses that looked cracked up, sprayed tb in a few spits, tightened down my exhaust mani as good as i could... Guess i could check the inectors
wer'e are haz teh embassys on our controls
