Water/Meth Injection Questions
Old Jan 4, 2007 | 05:22 PM
CobaltSS313's Avatar
Can someone tell me what is the pros and cons of each water/meth kit, is there one that is better than the other or is it just preference or what? Which one is the easiest?
Old Jan 4, 2007 | 05:42 PM
plus2ss's Avatar
The snow performance kit sprays before the S/C, the TAG kit has a plate that sits under the S/C that sprays the meth/water. They say that the snow kit cools down the S/C. The TAG kits says that spraying after the S/C prevents corrosion on the S/C rotor blades. As to wich one is better, I have no clue. Probably the TAG. Someone with one installed will have to chime in here.
Old Jan 4, 2007 | 05:43 PM
Ljavy17's Avatar
before the blower will make much more power.
Old Jan 4, 2007 | 05:44 PM
mattyfinch's Avatar
he was right on most of those.
the snow kit runs off you maf sensor, so it turns on a a desired amount of boost.. that is interchanable, you can also determine what percentage is sprayed at what boost levels.
the tag kit im not to familiar with, but i added 7-8 degrees of timing off mine, and jmac has added more then that with his...its a sweet setup
Old Jan 4, 2007 | 05:50 PM
yah that what i thought, plus i though that our rotors had a protective coating to protect them from corossion and whatnot. i thought the old gen 4 s/c were the ones that corroded.
Old Jan 4, 2007 | 05:52 PM
lsjwannabe's Avatar
idk if i would run the chance of corriosion of the rotors for a few more hp. i believe they added 5 or 6 degrees of timing and iat2's dropped 20*
Old Jan 4, 2007 | 05:59 PM
also what about the devils own kit??
Old Jan 4, 2007 | 06:44 PM
djt81185's Avatar
How is it having more contact time with the air...if anything it is having less time post blower due to lack of dwell time. Not to mention it will remove more heat pre blower since it is in the mixture as it is heated and compressed into the manifold resulting in a more homogeneous mixture.
Technically NO meth kits ADD horsepower...they allow you to tune it differently to make more hp and remove heat to allow you to make that more hp longer.
Turbo's have the luxury of having extra piping post turbo to add it and their parts dont generally produce the heat ours do.
Not to mention the meth/water mix in the s/c actually helps compressor efficiency of the blower by helping to seal the blades to the housing and also lowering the incoming air temps thereby packing more air per unit volume.
The gen v s/cs are perfectly fine with meth running thru them...Mine has no rotor wear from meth at all.
Dan
Old Jan 4, 2007 | 07:26 PM
Mase's Avatar
Dan
I'm telling you man the plate after the SC is real good. I'm running their kit now and I get 26* timing and seen 25*F in temp drops. Plus the added bonus of a tighter belt.
The dual nozzles spreads the spray out evently.
From my heat transfer classes I can tell you the coefficient of heat transfer is much higher with denser gases.
Old Jan 4, 2007 | 08:06 PM
Blown 4-banger's Avatar
Oh here we go again! Its gonna be an endless arguement! Just like weather a turbo or blower is better
Old Jan 4, 2007 | 11:06 PM
distillion's Avatar
ive been thinking about water/meth for a long time, i just dunno about the whole safety/relaiablity issues with them down the road, wouldnt want anything to break when i need to spray during wot.
id go with tags setup forsure.
listening for more info.
Old Jan 4, 2007 | 11:52 PM
Cobalt5533's Avatar
sorry to hijack but how long can you spray and how much does a refil for this thing costs ?
/end hijack
Old Jan 5, 2007 | 12:00 AM
DTM2188's Avatar
You just use window washer fluid to refill it. I think most people say they refill it once a month depending how you drive.
Old Jan 5, 2007 | 12:19 AM
Bad06SS's Avatar
I use the snow performance kit, and I spray pre-blower. I'm able to run 25+degrees of timing with 19-20lbs of boost, and see zero KR. Spraying before the blower does not hurt the gen V coating, and keeps the blower much cooler, allowing it to not be so heatsoaked. The water/meth evaporates just fine. Do you realize how hot it gets in that blower with a 2.5" pulley? Either way, I think any of the kits will work just fine, it all comes down to your preference.
Old Jan 5, 2007 | 12:24 AM
I run 25.5 degrees of timing with 19-20 lbs of boost with zero KR as well. I just have to put 101 or higher octane gas in it and flash the race gas tune. Better IMO then spending $400+ on a kit that you have to keep refilling every 3-4 weeks Yeah, it prevents heatsoak, but who cares. As long as you have good enough gas, you'll be able to run the timing.
Old Jan 5, 2007 | 10:31 AM
Bad06SS's Avatar
Yeah, I'd rather be able to run my "race tune" all the time vs only when I have race gas.
Old Jan 26, 2007 | 05:14 PM
Waylin22's Avatar
Hey cameron, thanks for havin STR killer get in touch with me about the kit, I think im gonna buy it as the water H.E spreay kit isnt going so well...Hey when do you wanna do the Cobra H.E
Old Feb 27, 2007 | 03:10 PM
godsfshrmn's Avatar
So does the TAG pump spray constantly while the engine is running at a low flow and the CA spray only at higher boost? I am confused as to what controls when and how much the pump is working.
Old Feb 27, 2007 | 03:26 PM
R33P3R007's Avatar
360 L337 User
me too. all i know is if i get the parts i am planning a wideband and meth are going to be needed.
brandon04
Oct 21, 2015 07:04 AM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
