What to do?
Old Aug 29, 2007 | 10:21 PM
blkcobaltsss/c07's Avatar
What to do?
I have been searching fo the past week or two, trying to come up with a definitive answer on what to do. And I still don't know!! I have a 07 Cobalt SS S/C with Injen CAI, Ingalls ETD, ZZP Header and Catted Downpipe and GMPP Exhaust. I was looking at buying the Cobalt-Addiction Stage 4 kit, but i don't want to get something that going to blow my engine. My question is what is the most i can do(Pulley Size, Injectors, etc, etc...) with the stock internals to get the most hp/tq. and without changing the blower. This is also my daily driver so has to be very reliable!!
Old Aug 29, 2007 | 10:24 PM
XM15's Avatar
Get the GM stage two and throw on a 2.9" pulley. It won't give you the most hp/tq, but it is a pretty safe way to go.
Old Aug 29, 2007 | 11:02 PM
If I bought the stage2 kit and a smaller pulley (ex:2.85") would everything fit fine and would i need to reflash?
Old Aug 29, 2007 | 11:16 PM
LopsidedJester's Avatar
you're starting to push the max of the injectors on the stage 2 tune, but some people are still even running 2.8" pullies. sooooo, the answer would be no, but you might want to think about getting an aftermarket tune to be safer.
Old Aug 29, 2007 | 11:38 PM
I guess what i need to know is what my limits are...
Could I run the CA Stage 3 kit + Professional Tune? or instead of the kit should i buy everything seperately then have it tuned?
Old Aug 30, 2007 | 12:54 AM
Infernokron's Avatar
The 2.8 Pulley is either maxing out 42# injectors or close enough it's scary, I would never run a 2.7 pulley on 42# injectors.. 2.8 is also about the smallest pulley you would want to run without quite a few cooling mods.
For reliability GM Stage 2 is your way to go, even if you *do* have a problem it's still under warrenty. The max you can get out of the motor and stay fairly reliable is probably somewhere in the range of 2.8 pulley, 60# injectors with harness, GM Stage 2 belt, 1 step colder plugs, and custom tune. Cooling mods on top of those can only help.
