what going on?
Old May 5, 2010 | 04:49 PM
crazywhiteboy89's Avatar
what going on?
i driven around not beating on my car and i get a code p1133 anyonw know what it is and is it bad?
Old May 5, 2010 | 04:50 PM
SSReepur's Avatar
Omg i have this same problem!!!
Old May 5, 2010 | 05:02 PM
are u serious what is it tho?
Old May 5, 2010 | 05:06 PM
SSReepur's Avatar
Yea its been doin it for like a month i believe its a oxygen sensor but not to sure
Old May 5, 2010 | 05:12 PM
o boy lol i getting my car tunned this weekend and i ask my tunner iif it safe to drive idk if it is. do u know?
Old May 5, 2010 | 05:20 PM
SSReepur's Avatar
Ive been drivin mine like that nothin has happened yet i hope not... Ive done reasearch but noone really said anythin in the threads so im waitin to c if anyone can help in this thread
Old May 5, 2010 | 05:44 PM
i look it a lean code bt that bad.
Old May 5, 2010 | 07:03 PM
skatin_boarding's Avatar
P1133 HO2S Insufficient Switching Sensor 1 ECM
Guessing its a 02 sensor but not forsure.
Edit found something for you. Sounds like you need a new primary 02 sensor.
http://www.amazon.com/Bosch-13455-Ox.../dp/B000BZJ7CG
From this thread- https://www.cobaltss.net/forums/show...ighlight=p1133
Old May 5, 2010 | 07:56 PM
ok do u know if it will affect my tune that i haven done this weekend
Old May 5, 2010 | 08:36 PM
IIRC that 02 sensor is the sensor that measure your afr for your stock ecu.
Old May 5, 2010 | 11:42 PM
SSReepur's Avatar
So i need a new o2??
Old May 6, 2010 | 08:51 AM
so i need it for the tune damm i thought the wideband would messure that but idk dam.
Old May 6, 2010 | 09:19 AM
Well the wide band does the wot tuning so you can tune the maf in because that sensor is not accurate enough. When your cruising around it is all off the primary 02 sensor (the one on the header) and that determines your fuel trims and if it should pull or put in fuel.
Old May 6, 2010 | 02:13 PM
just order it from gm dealer a $144 plus tax. hope it the right one.
Old May 6, 2010 | 02:21 PM
Wow on amazon they are under 50 bucks. Oh well hope takes care of the problem.
Old May 6, 2010 | 02:50 PM
06blackg85ss's Avatar
**** I get em for $74 walk in at chevy
Old May 6, 2010 | 05:10 PM
SSReepur's Avatar
I wonder if they actually work from amazon
Old May 6, 2010 | 05:12 PM
Sizzle06's Avatar
Wats dee point!!!!
Old May 6, 2010 | 05:14 PM
SSReepur's Avatar
Originally Posted by Sizzle06
Wats dee point!!!!
Yo motha
Old May 6, 2010 | 05:19 PM
Sizzle06's Avatar
You know her???
Old May 6, 2010 | 07:16 PM
i got mine is this the right on ? part # is 12568234
noone know if that the part # ?
Last edited by crazywhiteboy89; May 6, 2010 at 07:16 PM. Reason: Automerged Doublepost
Old May 7, 2010 | 02:46 PM
morring bump noone if that the right part#?
Last edited by crazywhiteboy89; May 7, 2010 at 02:46 PM. Reason: Automerged Doublepost
