What mod will gain more?
Going to a 3" downpipe and eliminating the cat and keeping the stock catback or switching to a custom 2.5" catback with the stock downpipe? Which will yield more horsepower and torque?
I'm thinking the DP will yield more because the stocker is a POS
I say the downpipe and 3 inch exhaust will give you more hp gain.. But instead of getting any old exhaust.. I'd say do a 3 inch custom like you were going to with the 2.5.. Or if your worried about loudness go 2.5 custom with catless dp.. Cuz 3 inch catless will be loud
this is something i don't get. why would you recommend this? by starting with a 3" and then going to a 2.5" you're creating restriction. the entire point of changing your exhaust is to eliminate restriction. so by intentionally creating restrictions, that defeats the point.
Do a Google search exhaust flow David Vizard. You'll learn a lot. I did.
Actually, I took the liberty of finding a good read for all of you.
http://www.geocities.com/motorcity/t...92/vizard.html
Enjoy.
EDIT: Dang nabbit .... only the first two pages of that link work.
Well, do a search on Google and I'm sure you'll find what I'm talking about.
actually by starting at 3 inch you allow the exhaust to exit the header with less restriction, and then by going down to the 2.5, you increase the exhaust velocity again leaving the downpipe and moving through the catback.
its better to have big to smaller, than the other way around.
and 3 inch has been to big for this car since very very few people actually move enough exhaust to keep the velocitys up.
most peoples ss/sc are under 280hp. above that, you may be pushing enough exhaust volume to pull it off. but not below.
hence why 90% of people with 3 inch experience a noticable loss in power, and a shift of the powerband a little to high in the RPMs
I have 3" catless downpipe. It isn't too loud. I stayed with stock exhaust. I believe too that it is best to get flow away from the header quickly, but keep the pressure further out. I still see 250 torque and pull great at low RPM. Stock exhaust otherwise is holding up well so far. Haven't even felt the need to mess with it.
Suprisingly, as the exhaust flows further down the pipe it cools. As it cools it becomes more dense and the flow slows. A way to help keep velocity up is to reduce the pipe diameter further down the exhaust pipe.
Enjoy.
Enjoy.
We don't lose that much power in the bottom end from going with 3"....With the issues that we have getting out the hole, I would say that 3" is a good idea to help with our 60' times and traction issues. A full 3" exhaust actually gives some pretty respectable gains as well. Check out Moderneco's posts about the Vibrant Header & DP combo with the Vibrant cat-back. Some damn good numbers posted up, and not much if any loss down low.
Picture courtesy of www.zzperformance.com
which i can say from personal experience, makes a great downpipe!
I had my stock cat replaced by a straight pipe on the stock DP and the sound was sooooo shitty. Plus the fact I was not running HPTuners so there was some sensation of performance loss. I got it re-installed for now (all stock dp).
