What Next
Old Apr 28, 2009 | 10:47 AM
venum_us_2002's Avatar
What Next
Mods in sig, where to go next for more performance?
Old Apr 28, 2009 | 10:48 AM
JERMzSS's Avatar
Ls1?
Old Apr 28, 2009 | 10:49 AM
ShortStack's Avatar
Smaller Pulley.
Different Power Adder (supercharger or turbo)
And ATLEAST a 2.5" exhaust.
Old Apr 28, 2009 | 10:50 AM
Brenticus's Avatar
get the TVS blower.
Old Apr 28, 2009 | 11:24 AM
think my GMPP exhaust is that restricitve? I have thought about getting a custom 2.5 with a big Magnaflow resinator. Or should i go to 3in?
TVS is a little out of the question right now.
Would going to a 2.7 make that big of a difference?
Old Apr 28, 2009 | 11:44 AM
ShortStack's Avatar
Id go to a 2.6.
Yes that gmpp 2.25" is holding you back... if your gonna go down to a 2.6 or a 2.7.. go 3".. if not.. 2.5" is fine as long as its mandrel bent.. if its not.. go for a 2.75".
Old Apr 28, 2009 | 12:29 PM
Bika's Avatar
Fail Less.
2.7" and a bigger exhaust. maybe up the meth nozzle and retune it.
Old Apr 28, 2009 | 12:32 PM
Stiner's Avatar
2.7 exhaust ported head retune then save for tvs
Old Apr 28, 2009 | 03:41 PM
coopn8r's Avatar
2.6" Pulley, Run a 3" exhaust, Port the Head, Larger Meth nozzle, Switch to a 90/10 mixture and add a H/E or a Dual Pass - ReTune
Old Apr 28, 2009 | 05:48 PM
heard you should not go over a 50/50 because of fire hazard
Old Apr 29, 2009 | 01:01 AM
coopn8r's Avatar
Fire Hazard.. Explain?
Old Apr 29, 2009 | 02:00 AM
Zach06CobaltSC's Avatar
Meth is a highly flammable liquid.
Old Apr 29, 2009 | 10:58 AM
What he said.
If you go over 50/50 it becomes flammable.
Old Apr 29, 2009 | 11:05 AM
ShortStack's Avatar
umm....
its supposed to be?
75/25 would yield better results with the supercharger.
Last edited by ShortStack; Apr 29, 2009 at 11:05 AM. Reason: Automerged Doublepost
Old Apr 29, 2009 | 11:18 AM
SCcobaltSS's Avatar
Above 50/50 does pose more dangers, but it should be fine.
I say drop pulley sizes, bigger exhasut or Turbo build?? haha
Old Apr 29, 2009 | 11:20 AM
ShortStack's Avatar
^^^ Can you PM me about your meth kit please.
Old Apr 29, 2009 | 11:31 AM
coopn8r's Avatar
Crazy talk.. Go big or go home.. You asked for what you can do next for a better gain and I told you.. 90 meth and 10 water you can add the **** out of timing and see real gains with the methanol.
How big are your *****?
Old Apr 29, 2009 | 11:38 AM
ShortStack's Avatar
I personally think that you would still need more water to cool for all the added timing..
75/25.
Old Apr 29, 2009 | 11:39 AM
im at 23* right now. Where would 75/25 put me
elite1's Avatar
You could get HIDs. I have projector HIDs for sale (6000K) for 110$(brand new). I dunno if they will fit 2nd gen, maybe they will. Cheers!
Old Apr 29, 2009 | 11:44 AM
ShortStack's Avatar
Every car is different... you can add probly 1-3 degrees..
Old Apr 29, 2009 | 11:58 AM
SCcobaltSS's Avatar
I dont think you can go much more. 1*.. I was maxed at 24* I thought... Could be wrong though.
Old Apr 29, 2009 | 12:03 PM
ShortStack's Avatar
he could also be running less boost, or more boost.. so ya never know.
Old Apr 29, 2009 | 10:27 PM
Bika's Avatar
Fail Less.
if you have huevos grandes, bump the timing up 1 deg at a time until it either shows kr or blows up. The cars I'm tuning are running straight -20 washer fluid which is at most only 40% methanol. Seem to like 24* to 25* of timing but they are only running 2.8" or 2.9" pulleys.
heres a potentially dumb question...
the methanol mixture is flammable above 50/50, so why would you want to run more timing with a 75/25 mix? wouldnt that increase the potential for pre-detonation?
Old May 4, 2009 | 01:54 AM
OneCOLDBIZL272's Avatar
the projector headlights gen 1 and gen 2 wont be able to handle the heat, least thats what the place that sold you the light should off told you... you can do it but i dont know how long the lense will hold up?
auston your next best bang for your buck would probably be a 3inch exhaust. and curt should be able to pull more out of your car with tuning in the future.
Last edited by OneCOLDBIZL272; May 4, 2009 at 01:54 AM. Reason: Automerged Doublepost
