what should i do for engine performance?
Old Jun 5, 2007 | 09:08 PM
bodykitredss's Avatar
i have a 2006 s/c ss i have stage two on there along with hahn full exhaust (header back) i also have the polyeurathain transmission mounts. and a injen and i was wondering what else i should do for engine performance. i feel like im at a lost on engine upgrades.
Old Jun 5, 2007 | 09:09 PM
joeworkstoohard's Avatar
smaller pully?
Old Jun 5, 2007 | 09:11 PM
how much smaller should i go and if i do that will it mess up my reflash
Old Jun 5, 2007 | 09:15 PM
i'm def no expert on the LSJ, but it does seem to be a popular change to make.
Old Jun 5, 2007 | 09:21 PM
2fastforyouraSS's Avatar
go 2.8 or 2.7 they are both popular sizes... im running the 2.8 i love it
Old Jun 5, 2007 | 09:29 PM
SS4ME's Avatar
If you switch to a smaller pulley, you may want to look into HPTuners.
Old Jun 5, 2007 | 09:31 PM
XM15's Avatar
If you go with a 2.9" pulley, you should net about 1.5 pounds of extra boost. This setup will run fine with the stage 2 reflash and belt.
It also couldn't hurt to look into getting cooling mods: https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/official-cooling-thread-59987/
Old Jun 5, 2007 | 10:01 PM
BlilBT's Avatar
Suggestion>>> Do the dual pass Setup with another H/E before you throw anymore heat thru the manifold! It will sustain More HP Longer without Heat soak!
Old Jun 5, 2007 | 10:16 PM
NJHK's Avatar
What is your goal for your car? Power wise?
Old Jun 6, 2007 | 01:56 AM
i would like to brake in to 12's and be over 300 wheel power. any suggestions
Old Jun 6, 2007 | 02:04 AM
JKennedy1612's Avatar
What is required in order to use a 2.8" pulley?
Last edited by JKennedy1612; Jun 6, 2007 at 02:05 AM. Reason: Automerged Doublepost
Old Jun 6, 2007 | 02:40 AM
any idea what ill run in the 1/4 if i go down to a 2.8 pully with all my mods
Old Jun 6, 2007 | 10:31 AM
mezzanno's Avatar
go with a smaller pully like 2.5, meth injection, 60lb injectors, ported blower, cai and full exhaust. With a good tune you'd have a shot at 300.
Old Jun 6, 2007 | 10:35 AM
u wont have to get a machined snout.. it bolts right up.. nething under 2.8 requires a machined snout.. all u need is the pulley system which u can get from pulley boys for $100
if u dropped down to a 2.8 u would gain roughly 10hp.. they say every .10 u go down u gain 5hp.. u might run a high 13 in the 1/4
Last edited by 2fastforyouraSS; Jun 6, 2007 at 10:35 AM. Reason: Automerged Doublepost
Old Jun 6, 2007 | 12:53 PM
SS4ME's Avatar
Actually guys have run mid 13s with ST2 and a 2.8 pulley. GM ST2 alone can net a high 13 second pass, if you have some skills.
Old Jun 6, 2007 | 01:27 PM
Johnboy12358's Avatar
Stage2 with 2.8 might be pushing it, I wouldnt go under 2.9 without cooling and monitoring. Get your IAT cooling in order before you mod too much, temps are killer on these motors. And 300 is hard to do on the stock blower w/o N2O I have read, be careful....
Old Jun 6, 2007 | 01:29 PM
portergraph's Avatar
GM Stage 3 w/50 shot
Old Jun 6, 2007 | 01:53 PM
DaREDss's Avatar
2.85 from zzp and stage 2 is good setup
Old Jun 6, 2007 | 02:01 PM
yea driving does play a factor.. its hard to get it down pact.. i've been to the track several times and have been driving since i could walk and i still have a lil trouble launching my car..
Old Jun 6, 2007 | 02:12 PM
blackngold20's Avatar
2.6 pulley, heat exchanger, dual pass intercooler, spark plugs, HP Tuners, and maybe a nitrous system
Old Jun 6, 2007 | 02:41 PM
machined snout
do you know where i cpuld find a machined snout or is it a do it your self?
Old Jun 6, 2007 | 02:45 PM
if you're looking for a smaller pulley, nherbst454, makes them that fit the stg2 hub - no snout needed... word is though - don't go smaller than 2.9 (2.85 very smallest) to be safe w/stg2 tune
Old Jun 6, 2007 | 04:42 PM
RBC's Avatar
RBC
Yea I think I am going with a 2.85" pulley from Nate with one step colder plugs. What do some of you guys think about this set up?
Old Jun 6, 2007 | 04:43 PM
Jimmys2007CobaltSS/C's Avatar
nice mods ..i loike the hahn exhasut but its too steep for me
Old Jun 6, 2007 | 05:48 PM
u can get the machined snout from intense-racing.com..
