What size TVS pulley can be safely run?
Old Aug 27, 2009 | 06:40 AM
ajm5036's Avatar
I wanted to get opinions from all you other TVS guys out there. I'm wondering what size pulley I can safley drop down to without adding any addition cooling mods or meth?
I'm already running the big OTTP heat exchanger and hatrickstu mod and my iat2s are never over 140 and tend to stay right around 95-100. What do you guys think?
What I'm thinking of doing is either:
79 lb injectors
smaller pulley (size....not sure)
ls4 throttle body
3" intake
tune
or just:
79 lb injectors
smaller pulley
tune
What do you guys think? Would either of these options net me good safe power?
I'm at 274whp and 242wtq what do you think this could do for me? Predictions, comments?
Old Aug 27, 2009 | 08:05 AM
Zooomer's Avatar
Supporting Vendor
what are you mods now? how much timing do you run now? what size pulley is on there now? what octane do you run?
Old Aug 27, 2009 | 08:54 AM
ajm5036's Avatar
TVS with 80mm pulley (stock), K&N intake, Hahn header, zzp 3" catless downpipe, Hahn 3" cat back, 60 lb injectors
Old Aug 27, 2009 | 08:59 AM
lsjwannabe's Avatar
79 lb injectors
ls4 throttle body
3" intake
tune
or just:
79 lb injectors
smaller pulley
tune
Personally i would look into a dual pass/option b setup, as efficent as the blower is it will still be producing nearly 23 psi on the 75 mm and 25 psi on the 70mm.
I would suggest looking into meth if your serious about the car the additonal timing will be of great use once you start to push bigger boost numbers.
You could run the 2.9" safely with 60's and meth or just 79's but heat will increase with the increased pressure.
Old Aug 27, 2009 | 09:14 AM
Darkmanx's Avatar
Stick with stock pulley for now
Old Aug 27, 2009 | 09:25 AM
ajm5036's Avatar
Any other opinions? I appreciate all these but they are basically avoiding my idea. I know I can make more power with meth by pulling timing, but the question is what size pulley can I safely drop to and what power levels do you think my 2 ideas would net.
Old Aug 27, 2009 | 09:29 AM
rallycobalt06's Avatar
i agree with Darkmanx on this.... stay with the stock pulley, get the rest of your mods figured out (bigger injectors, meth, dual pass, etc etc etc). then get it retuned, you might be happy with that. if not, then u can start dropping pulleys
with what you have now, you can drop the to 2.9" pulley (i'm not sure of the mm). as for your 2 ideas, i have a 3rd for you to consider....
return style fuel system
3" intake
tune
Last edited by rallycobalt06; Aug 27, 2009 at 09:29 AM. Reason: Automerged Doublepost
scott allen's Avatar
how much does the dual pass and option b help?
Old Aug 27, 2009 | 09:31 AM
qwikredline's Avatar
an option B tank works better than a stu mod no offense to Hatrick he is a good guy. You need to self bleed. I have an 80mm pulley with meth and will go to 70 mm but not until i revise the fuel system. I am on 60's. The tune is at the heart of your power concerns, I am on v.4 and continue to log files. Nopt there yet and its not easy. Its a work in progress, my car is a dd.
The dual pass helps some a single pass even more but that single pass is not an easy deal so stick with dual pass its easy. The laminova company went out of business so there is not an infinite supply and the cores are easy to damage.
The restriction of the laminova set up and the compromises made there exist but its not a big deal as no one is going to practically want more than say 320 whp for a dd. The cost of changing all the cooling stuff is hard enough with the oem conponents ; the cost is silly doing anything different. Water to air cooling is not that difficult from an engineering point of view, and it is possible to re-invent the wheel but not worth the cost. Even the supply of sc cars is finite and the guys who really want big power numbers turbo charge anyway. So to sum it up, get meth, either return style with 60's or 79's, fix your cooling mods and tune tune tune. You could pay Area 47 to help you he has done a lot of work on tvs cars more than anyone else I know...
ajm5036's Avatar
3" intake
tune
Would the return style even be worth it? And what about ls4 throttle body? I know everyone hates on it but does it net gains?
Old Aug 27, 2009 | 09:34 AM
lsjwannabe's Avatar
Probably around the 290 whp range, depends where you leave timing and the afr really.
Yes the ls4 tb does net gains, most complain about the driveabilty becuase the throttle is much more sensitive. Just have to tune a little and relearn driving the car.
Last edited by lsjwannabe; Aug 27, 2009 at 09:34 AM. Reason: Automerged Doublepost
Old Aug 27, 2009 | 09:36 AM
ajm5036's Avatar
Ok final idea... since you guys obviously hate my original ideas...
what about:
return fuel system
meth
and pulley drop
[/QUOTE] Yes the ls4 tb does net gains, most complain about the driveabilty becuase the throttle is much more sensitive. Just have to tune a little and relearn driving the car.[/QUOTE]
What kind of gains would it show on average? And would a 3in intake be a must? Or can it work on any intake?
Old Aug 27, 2009 | 09:37 AM
lsjwannabe's Avatar
Depends on the pulley size and how agressive that tune is.
With the return style you can lower pressure at idle to help idle qaulity and add fp 1:1 in boost to raise it when you need it. You can keep your 60's for anything the tvs has.
My suggestion 2.75" thats really the usuable limits of the tvs on a stock head car.
Gains are across the board most usually have seen 7~9 whp across the rpm range and dieing off up top.
Old Aug 27, 2009 | 09:43 AM
ajm5036's Avatar
So would you agree that my best bet would be to get a return style, meth and 2.75" pulley? I don't think I'd go for the ls4 because I would like the throttle response to remain smooth. What kind of power (ball park) could I expect with this combination?
Old Aug 27, 2009 | 09:45 AM
are you saying going from a stock pulley to a 2.75 will only give you 7 to 9 whp?
Old Aug 27, 2009 | 09:46 AM
lsjwannabe's Avatar
I would imagine numbers close to or even eclipsing my numbers if your tune is good.
313/268 wtq 11.0 afr 16* timing no meth with the 2.75" and return style
Josh@ottp's Avatar
One other thing that seems to be over looked here is your exhaust. You have one of the worst flowing headers on the car, get a mid-length first.
Old Aug 27, 2009 | 09:47 AM
ajm5036's Avatar
He meant the ls4
I appreciate the idea, but I probably wont.
is that on stock internals?
Old Aug 27, 2009 | 09:48 AM
what about:
return fuel system
meth
and pulley drop
What kind of gains would it show on average? And would a 3in intake be a must? Or can it work on any intake?[/QUOTE]
I am doing the return style with a pulley drop already have meth. You need I suspect a 3 inch intake, I gotta redline and we have a trailblazer inlet box so we are way better than you Oh and the LS4 tb? fuggedabowdit
Old Aug 27, 2009 | 09:50 AM
ajm5036's Avatar
You think a 3in intake on a stock tb is a must?
Old Aug 27, 2009 | 09:51 AM
lsjwannabe's Avatar
yep.
Old Aug 27, 2009 | 09:54 AM
ajm5036's Avatar
Right so the consensus is forget all that other crap...
Meth
Return style fuel system
2.75 pulley
tune
.....win
am I right?
Old Aug 27, 2009 | 10:10 AM
Josh@ottp's Avatar
Meth
2.75 pulley
tune
.....win
am I right?
At some point you will need to change out the exhaust, otherwise you will be limited on the amount of timing you can run and the power you will make.
Old Aug 27, 2009 | 10:16 AM
^listen to this guy about the exhaust. it's not a "must" at the moment, but you'll eventually need to upgrade that header.
i'm going to RPM tomorrow morning, i'll let you know how i do.
