What Would Cause This??
Old Dec 16, 2011 | 11:08 AM
FryLoch's Avatar
On the freeway last week and did a quick run against a 350Z. Started in third gear and hit the rev limiter one time. Just shifted 1/4 of a second too late when I go into 4th the car shudders and makes a loud exploding kinda sound. Factory gauges go nuts, tach is al over the place, boost same and my intercepter reads IAT2 of 305... Check engine starts flashing and I'm like ****, I just killed my car wtf its just GM stage 2 with 2.99...
After the Z catches up and blows by me, car calms down and drives like normal. IAT back to normal. I decide a minute later well let's see if it does it again. Did a pull in third again no issue.
Codes pulled
P0171- recurring
P0097
P0300 I think was the other
I checked the codes and it said low voltage temp sensor and multiple misfires
Sorry about the rant.
Old Dec 16, 2011 | 12:03 PM
mrbelvedere's Avatar
P0171 Fuel Trim System Lean -PCM
P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage -PCM
P0300 Engine Misfire Detected -PCM
p0097 could be a bad 5v reference wire a bad alternator
Old Dec 16, 2011 | 12:08 PM
defo98's Avatar
So where you winning before it happened? lol
Old Dec 16, 2011 | 12:20 PM
FryLoch's Avatar
Yes lol. About 3 lengths ahead going into 4th
Old Dec 16, 2011 | 02:25 PM
Vander Nars's Avatar
Codes pulled
P0171- recurring
P0097
Back to the future?
Old Dec 16, 2011 | 11:24 PM
Sharkey's Avatar
myself id tackle the p0097 code first. the p0171 code monitor does not run when your under boost, only under vacuum. the random misfire could be a result of the failsafe for the p0097. when your iat2 sensor reports something as high as 305*f its going to pull a lot of timing and quite possibly add fuel. this could cause a misfire, sounds like you had some misfiring going on.
follow the diagnostics for the p0097 code first.
Old Dec 17, 2011 | 02:49 AM
FryLoch's Avatar
What would that be? I realize the P0097 is the issue, just replace the sensor?
Old Dec 17, 2011 | 12:09 PM
get the charging system checked
