What you take??
Old Jan 15, 2012 | 12:32 AM
insylem's Avatar
As far as I understand HP > 300 = Upgraded Internals for LSJ.
Get the "LSJ Power Book" It walks you through how to make a 300 hp LSJ
Old Feb 21, 2012 | 03:24 PM
Badboyz1620's Avatar
Kinda dissapointed.... Yesterday i got a present, My buddy took my car for me to get it dyno tune. I have e85 on 60's full cooling mod, opt b. running around 20lbs of boost, mid lenth cti headers 3 in dp high flow cat, 2.5 cat back no res magnaflow muff. zzp 3in intake and the numbers was below 250 to the wheels, but so called 285 to the motor. im so upset happy with the present but upset cuz i spent all this money plus a present and still cant break 300. plus i have sputter at 5760rpm. I must admit 1st gear forget about it. But i dont have my top end any more. Looking at the dyno sheet i power droped off at 6k. Really not happy. Slap on a t3/t4 turbo and be at 350 easy. What to do!!!!!!!
Old Feb 21, 2012 | 03:39 PM
Zooomer's Avatar
Supporting Vendor
mod list?
Old Feb 21, 2012 | 03:41 PM
sujomatt's Avatar
What makes u think its gonna make good power with a turbo if ur car is running like crap now? You need to investigate the issue before dumping more money into the car. Just my .02 tho - good luck man
Old Feb 21, 2012 | 03:51 PM
07LSJ's Avatar
compression test, check for leaks, get a custom tune. not saying zzp tunes are bad but they are canned tunes, basically to get you started. 250 is very low actually for all you have. how are your AFR looking like at WOT
Zooomer's Avatar
Supporting Vendor
stock lsj w/m62
2.7 pulley
60's lbs injectors
3in zzp intake
dual pass
stage 3 H/E into stock H/E
Z06 MAF sensor
CTI headers 3" dp to 2.5
stock exhaust piping thrust turbo muffler
No cat or Resonator
zap can tune
sportline springs
235/40/18s all around.
I would guess the small pulley is hurting you, esp with where it made peak power. It needs a 2.9
The stock exhaust is hurting you too.
Old Feb 21, 2012 | 03:53 PM
nizzle's Avatar
Checked your bpv lately?
Old Feb 21, 2012 | 05:34 PM
currently as it sits
custom tune by horsepower solution on e85
243.35
3in zzp intake
2.7 pulley
cti headers midlenth 3 in dp
2.5 cat back no res magnaflow muffler
60's injector
option b
dual pass zzp
stage 3 heat exchanger
a/f is around 9-10:1
at wot i see 11 on the wide band which has been recalibrated. And it sputters starting at 5674 ish.
Old Feb 21, 2012 | 06:07 PM
Old Feb 21, 2012 | 07:59 PM
Whitnith's Avatar
243.35
3in zzp intake
2.7 pulley
60's injector
option b
dual pass zzp
2.7, 60s, and E85 isn't going to work... One of those needs to change. 2.7, 80s and E85. 2.7, 60s, and pump gas. Or bigger pulley, 60s, and E85.
Old Feb 21, 2012 | 08:54 PM
  #36
this is annoying.
Old Feb 21, 2012 | 11:51 PM
  #37
mrbelvedere's Avatar
you dont need to swap out the internals the stock stuff is plenty stout to handle the job
243.35
3in zzp intake
2.7 pulley
60's injector
option b
dual pass zzp
your tune is whats holding you back its way rich 12.0 afr on e is more then safe find someone who can actualy tune a lsj
Old Feb 22, 2012 | 12:47 AM
  #38
insylem's Avatar
Originally Posted by Blowncavy
^no you can not get the real hp number's from interceptor lol.
Im sure you can get somewhat CLOSE if you enter the correct HP Correction in the setup for it.
HP Correction will apply to your MPG reading and your HP reading. I used / tracked my MPG actual Vs Interceptor and did the math, for my car I had to enter 075 for my HP Correction.
Old Feb 25, 2012 | 01:45 PM
  #39
just went to se joe, he compared my old tune from zap and the new bs e85 tune from hp solutions and only two parameters was changed. the mac tables and the ve if i remember correctly. Very upset 400 for a dyne tune that was not tuned properly.
Old Feb 25, 2012 | 02:00 PM
  #40
klloyd's Avatar
You should be running 80's with e85. I have basically the same mods but i'm on meth not ethanol and I put down 280hp/256tq on a BYT tune. I am pretty much at my max with where I can go unless I get into the head and motor. I wanted 300hp but I don't see that happening.
Old Mar 24, 2012 | 11:10 PM
  #41
yea i gave up on the modes for now just want a tune and for it to run right zap has it to lean lol. but I'm going to get it tuned the right way this time. the last tuner just changed two parameters didn't even do it right hacked it all up. bye bye e85.
Old Mar 24, 2012 | 11:55 PM
  #42
Vander Nars's Avatar
who the **** is zap?
Old Apr 3, 2012 | 03:44 AM
  #43
zzp
