Wheel hop
Old Nov 18, 2007 | 02:29 PM
yellowspeed5's Avatar
Wheel hop
Will torque damp be enough to eliminate wheel hop or should I go with traction bars?
Old Nov 18, 2007 | 02:31 PM
ChefSS's Avatar
If you want to eliminate wheel hop get a motor mount or tranny mounts. The tranny mounts alone would get rid of almost all the wheel hop.
Old Nov 18, 2007 | 02:32 PM
an0malous's Avatar
TD wont get rid of it, but it will help alot.
it also depends on what mods you have....if your running slicks/drs....if you race on the track....
if you want to eliminate it all together, a TD wont do it completely.
Old Nov 19, 2007 | 06:56 AM
snobrdrdan's Avatar
Better/grippy tires help too & play a role
Torque damper is good for everyday/normal driving
SMM's would be better for normal/harder driving (you're gonna get vibrations in/throughout the car)
From what I hear, the traction bars make a lot of noise
Old Nov 19, 2007 | 07:26 AM
TurboTechRacing's Avatar
Exactly, check ours out if you are interested at www.TurboTechRacing.com
Old Nov 19, 2007 | 09:02 AM
EmperorJJ1's Avatar
anyone know if the tranny mount vibrate much? I would like a lil less wheel hop although newer tires helped quite a bit... I can't get a TD or turbo tech SMM
Old Nov 19, 2007 | 09:05 AM
lsjwannabe's Avatar
yes the tranny mounts give you vibs. I have had control arm bushings as well but they fell apart, but while i was running that setup i never had wheel hop. Tranny mounts alone will not cure it at all when you start to push some power. I wheel hop from any roll in second 30,40,50
Old Nov 19, 2007 | 09:20 AM
Jumpin Fool's Avatar
Cool My .02
I tried the TD, didn't like it. I race autocross, 1/4m, 1/8m, 1on1 circle track drag, and it wasn't enough. I went all out with a Bwoody full set of mounts and traction bars. You better believe I don't have any wheelhop .
Yes, you will get vibrations. But I think too many people jump on mods that they don't really need then want to cry about a little discomfort. If you really race, you need to eliminate wheelhop. If you just want to get a mod to say you have it, you need to rethink your priorities.
If you really want to see this car perform, eliminate your wheelhop with the mounts, stiffen up your suspension with swaybars/coilovers(not just lowering springs), and most importantly, learn how to drive the car for all it's worth before thinking it needs more hp than the car/driver can handle in the first place. I have personally proven that the car has plenty of power to be competative as is, as long as you can get the power to the ground.
Boy, it got lonely up on that soapbox.
Old Nov 19, 2007 | 09:23 AM
lsjwannabe's Avatar
the vibs i can handle but the squeaking from the tractions bars is not something i would want. I don't want people to think my **** is falling apart
Old Nov 19, 2007 | 09:27 AM
D4u2s0t's Avatar
they vibrate a little bit. i don't think it's that bad though. it's a trade off though, and it's one that's totally worth it. the people that complain about the vibes are just being silly. it's like complaining after you put your exhaust on that it's louder than stock no **** it is!
why can't you get a td or smm
Old Nov 19, 2007 | 09:30 AM
Talking Not a problem
Let'em think it's falling apart....
Then leave'em wondering what happened when your "rikity piece of **** cobalt" blows them away.
Originally Posted by D4u2s0t
...it's like complaining after you put your exhaust on that it's louder than stock no **** it is!
AMEN BROTHER
Old Nov 19, 2007 | 09:41 AM
lsjwannabe's Avatar
AMEN BROTHER
they only help you spin not hop, my first and second are useless anyways
Old Nov 19, 2007 | 10:32 AM
Question
they only help you spin not hop...
Who wants anything that's going to help them hop?
So, then, you take off in third?
Old Nov 19, 2007 | 11:10 AM
lsjwannabe's Avatar
no i just go half throttle in first and then try to feather second, i can't mash it or a spin and hop
Old Nov 19, 2007 | 11:16 AM
Area47's Avatar
Rent me! per hour
same here
Old Nov 19, 2007 | 11:21 AM
Originally Posted by Area47
same here
Thanks Area, for chiming in. It just wouldn't be a thread without some kind of comment from you.
Old Nov 19, 2007 | 11:22 AM
lsjwannabe's Avatar
damn pirelli's
Old Nov 19, 2007 | 11:29 AM
Area47's Avatar
Rent me! per hour
i do what i can.
i have the ttr mount, well. it does not cure wheel hop.
depending on the pavement type, i could either, hook, mild hop. or flat out spin in second.
Old Nov 19, 2007 | 11:33 AM
lsjwannabe's Avatar
if someone could manufacture a control arm bushing that stays together that is were the money is at. I would just spin with them in, now my car hops like its the things job
Old Nov 19, 2007 | 12:00 PM
k thanks guys
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
