Where to go from here...
So far I got the ZZP stage 3 (2.9 pulley), 3 inch Downpipe, 3 inch CAI.
I'm going to buy the Koni sport struts as my struts are all but shot.
After that ill have about 1,200 to spend. I'm looking to get the ZZP 3 inch cat back exhaust, LS4 throttle body and pulley down to 2.7. Anything I'm missing?
um forget the pulley and full exhaust, especially forget the ls4 unless ur getting a tvs. those are only good for a few hp
isntead, take that 1200 and get cooling mods. make that 2.9 push cold boost instead of hot boost.
instead of an exhuast focus on opening up the header. get a header first.
get the exhaust done a 2.5 system is more then enough for you and add a methanol kit and run a 80/20 mix on a 10 to 14 gph nozzle so you can ramp the timing in or put it on e and get a pornstar tune
I have dual pass and stage 3 HE with the stage kit, and I'm on 50# injectors.
I've seen debate after debate whether 2.5 or 3 is better for the SC/SS. I may go 2.5 to save some cash
Also someone mentioned headers, I haven't really looked into them so if you could help with where to buy, best for the price? I may get them instead of TB and pulley down.
I hope to go tvs down the road also.
