Where to put Meth Injection Nozzle in intake
Old Mar 14, 2008 | 03:00 PM
Werewolf SS's Avatar
Hey guys for those that have done meth injection where did you put the nozzle in the intake. The below pic shows someones cobalt and where I have circled shows an area on the stock intake that has a hose coming of it. On my vechile there is no hose just a nipple into the intake. Is that a good place to mount the nozzle? Also is thier suppose to be a hose going into that or am I missing something on my car?
Thanks!
Old Mar 14, 2008 | 03:01 PM
invisible's Avatar
You can put it anywhere about 5 inches away from the throttle body. But its up to you if you want it to be stealthy or shown. (top or bottom)
Old Mar 14, 2008 | 03:02 PM
Drakonen2000's Avatar
that would be where the intake sucks the fumes out of the head cover...its an emissions thing...
Rangerondubz's Avatar
There is suppose to be a hose coming from the valve cover into the intake.
invisible's Avatar
On your I would put it right after the bend about 1 ich before your red circle is.
Old Mar 14, 2008 | 03:06 PM
Okay so if thats the case ummmmmm why am I missing a hose?
What exactly does it do and is it critical to the car?
Old Mar 14, 2008 | 03:09 PM
invisible's Avatar
You mean yours isnt there at all?
Look under your hood cause i find it hard to believe that the hose could fall all the way of and out through the bottom.
Old Mar 14, 2008 | 03:10 PM
Nope Just a nipple sticking out with a hole. Been like that as far as I can remember.
I'll check this evening I'm at work right now.
Old Mar 14, 2008 | 03:11 PM
invisible's Avatar
Well look and see if the other side is connected to your engine. And if it is well then the rest is explainable.
Old Mar 14, 2008 | 03:12 PM
What other side?
Old Mar 14, 2008 | 03:14 PM
invisible's Avatar
Top left hand side of your engine. there will either be the hose or another nipple. ( right above the left side of the header)
When you can take a picture of your engine bay and we can tell you if you have it or not
Old Mar 14, 2008 | 03:15 PM
95cam86roc's Avatar
I think ima mount my nozzle on the bottom side of the intake so no1 can see it.
Old Mar 14, 2008 | 03:16 PM
Alright I'll check tonight so what does it do an it must not be important if I've been running it for months without issue. I never closely looked at my eninge bay till I got Stage 2 and I noticed that the nipple was there but didn't think any thing of it. That was almost 4 months ago and I've put 4000 miles easily on the car since with two drag strip trips and many races.
Old Mar 14, 2008 | 03:18 PM
invisible's Avatar
I'm not sure how important it is but im pretty sure that its good to have it on.
Old Mar 14, 2008 | 03:19 PM
well...if you dont have it and its just a nipple...you are sucking un-metered, un-filtered air....no bueno!
Old Mar 14, 2008 | 03:22 PM
invisible's Avatar
Thats what i did.
Old Mar 14, 2008 | 03:26 PM
95cam86roc's Avatar
Thats what i did.
Any tips on how you went about this? Take the intake out i assume... And where exactly did you put it? Intake or coupler?
Old Mar 14, 2008 | 03:52 PM
Invisible thanks for telling me where the pipe orginated I went to move my car at work popped the hood and found it. It was moved out of the way and the pipe ran toward the back making it look like it went to the firewall. So it's reconnected now Thanks!
I think what happened was when the techs at the dealership put stage 2 on they moved it and forgot to put it back on.
So for the past 4 months it's been like that with about 4000 miles put on the car 2 drag strip days and several races.
How much damage was done?
Old Mar 14, 2008 | 03:54 PM
hopefully not too much...you would just be running lean and maybe suckin up some crap...nobody can really say how much damage it did / did not cause
Old Mar 14, 2008 | 04:21 PM
invisible's Avatar
I put mine on the rubber coupler. Just drilled through it then put the knozzle on.
No problem. I dont think there will be any damage. You should be ok.
Do you live in the city and drive in the city and not on dirt roads alot.
Old Mar 14, 2008 | 04:23 PM
07cobaltss's Avatar
stealthy FTW
Old Mar 14, 2008 | 04:25 PM
invisible's Avatar
Originally Posted by 07cobaltss
stealthy FTW
Yea however it does kinda suck for when im trying to show it to people cause im like look what i got then there like I dont see anything.
Old Mar 14, 2008 | 04:55 PM
07cobaltss's Avatar
lol^ bah they dont need to know, run what ya brung
Old Mar 14, 2008 | 05:01 PM
invisible's Avatar
true true
