Whipple 1600 AX
Whipple 1600 AX
What all is needed to throw one of these bad boys on. I have the money for the mod, and its going to be my first to the car, so can anyone outline me what i need in order to put in on?
Thanks
Thanks
an adaptor plate will be needed for the SC and TB. But if youre going to be the first to do it, you are the one that is going to be finding all the problem with it. No one knows until they try
Originally Posted by Mines_Better
i heard that the adapter plate doesnt fit right under the hood, i could be wrong though...
Moderator Alumni
Originally Posted by zinner
I think thats the case on a Redline with the M90. I don't know if someone has done the research/math to know if its the case with an SS/SC and a whipple.
Originally Posted by c7015
** All DSM's ...however their "Dent" is for the Cam Gears
but that was only on turbo models. The NA 420a's had the engine on the other side and the hump was totally useless. I miss my 96 GST
yes a given ...I miss my 92 tsi awd
Edit: but not the timing belt/everything attached to it and certainly not the oil it burned ....
I will have it done as soon as i sell my other car, need the $ to buy all the parts, I put the whipple on a credit card and its on order, but the mounting stuff, and a cooling option are going to come from the funds of selling my 95 eclipse. Yes im going to do it, and i plan to write up a guide for it, with picutres.
Thanks
Thanks
Then you can start to think about putting the whipple on.
Originally Posted by Alex47
First you will need a upgraded cluch ,injectors, and fuel pump.
honestly im keeping the cluth till i burn the current one, fuel injectors im waiting on stage kits, and the fuel pump i never thought about i honestly havent even looked a new one up yet, or teh stock ratings on mine
you'll need an externally bleeding bypass valve, a method to control A/F, the stage 1 kit, likely a new clutch, adaptor plate, and you'll need to make sure the S/C itself spins the rigth way before blowing your money on the blower
Looking intot his more, this might actualy directly bolt onto our car, one very very very important thing i havent been able to find, is does it spin the same direction as the eaton m-62, you guys might laught but i know some chargers spin clocwise and otehr counter.
Also if youd o this upgrade from what imr eading you can crap the stock intercooler, save space and weight.
All you need in a bypass of some sort to not restrict the maximum boost.
Its been a long day if i left anything out ill correct it later.
Short rundown 1500 for charger possibly all you need + bypass for almsot double the S/C output.
worst case
Charger 1500
bypass ?
Custom bracket 400
tb mount ?
map or maf sensor mount ? <the one ontop of stock m62 charger
Am i missing anything major
worst case
Charger 1500
bypass ?
Custom bracket 400
tb mount ?
