why does my car stutter and shudder?
Old Sep 8, 2011 | 05:45 PM
ok i want to get to the bottom of this. i've searched the threads and havent found much in direct answers, so for anyone else thats had this problem, please let me know what you did to fix it
SYMTOMS: Mostly on cold starts and pretty much driving off, for the first few minutes of driving the car will stutter while in gear, like i'm going along and it feels like the fuels gets cut out in quick bursts. also, once in a while AFTER the car's been warm and driving, it will 'hiccup', like i just lose all my power for a split second.
Engine in general kind of vibrates alot, and seems to go through 'cycles'. as in, every few seconds on the dot you can feel the engine do something like a misfire.
I've heard MAP sensor, plugs, fuel injectors, maf sensor...
I've cleaned the TB real good, and am yet to check the other things. looking for someone thats had the same experiences and issues im having so i'm not taking shots in the dark by buying parts i might not need.
Thanks a ton, will explain more if need be, just ask questions.
Car has 38k on it, no issues minus this stuff
Old Sep 8, 2011 | 05:47 PM
CobaltVenomSS's Avatar
id start with the spark plugs... get some NGK BKR7E's
Old Sep 8, 2011 | 05:48 PM
might be that time, huh? thanks
Old Sep 8, 2011 | 05:50 PM
EXsoccer1921's Avatar
might be a cobalt
Old Sep 8, 2011 | 05:53 PM
umrdyldo's Avatar
Do you have any way to log your car. would like to see what the car is doing when you feel that.
Old Sep 8, 2011 | 05:57 PM
unfortunately no. no CEL either, maybe i'll go scan it at autozone just to make sure theres nothing funky going on.
Old Sep 8, 2011 | 06:16 PM
Frew's Avatar
might be a cobalt
This, my car doesn't like to throw one code at a time its usually two or three, they get lonely ya know?
Old Sep 8, 2011 | 06:18 PM
05Slowline's Avatar
and random ones at that, that never come back lol
Old Sep 9, 2011 | 08:32 AM
well idk if i solved the problem yet but i cleaned my MAF last night, ordered new NGK BKR7E spark plugs, and while i was at it checked the oil. interestingly enough, i was overfilled by over a quart! think its because my buddy was dyslexic when we did my oil change 2 months ago and thought the manual said 7.4 qts
Old Sep 9, 2011 | 11:20 AM
umrdyldo's Avatar
Yeah over oil could be a huge issue.
Old Sep 9, 2011 | 11:47 AM
FryLoch's Avatar
Do not put those plugs in your car, they burn up quite easily. They're too cold for the car.
If you do replace your plugs use the correct temp range.
Old Sep 9, 2011 | 11:50 AM
Whitnith's Avatar
Unless that's what you've been tuned to run... Run whatever spark plugs your tuner said to run.
Old Sep 9, 2011 | 11:57 AM
FryLoch's Avatar
I never recommend them, they caused a detonation issue with my car and I know of two other cars that burned these plugs up after only a short time like <30k miles.
Just a side note though I am running GM Stage 2 and a GM 2.99 pulley
Old Sep 9, 2011 | 12:07 PM
Whitnith's Avatar
The BKR7E is like *the* plug that most LSJs love to run on though. Even if they burn through them pretty quickly. I got 7 months and about 7k out of mine. If that extra $30 every 6 months or so is going to bankrupt you, get out of modding cars. Gotta pay to play.
Old Sep 9, 2011 | 12:08 PM
steddy2112's Avatar
Old Sep 9, 2011 | 04:17 PM
ive had my BKR7e's for as long as i can remember and ive gone thru so many different setups from 2.8 M62 to now a TVS 2.9 and car runs fine
Old Sep 9, 2011 | 04:24 PM
Originally Posted by steddy2112
YES!!! lol well i'm not tuned yet or anything, stock car with injen and bad mab. soo idk if i should still put these plugs in or what now... gap is .032 on these cars right? or do u need to gap them?
for the record i'm going 0ttp stage 2 soon
Old Sep 9, 2011 | 05:10 PM
Frew's Avatar
Haha and this
Old Sep 9, 2011 | 05:12 PM
Frew's Avatar
Autolite 3922 gapped to .035 nuff said
Old Sep 9, 2011 | 05:25 PM
Sox-Fan's Avatar
Got Brakes?
cat warmup. Get your car tuned. Have the turner remove cat warmup. Problem solved.
chefhhr
Oct 26, 2015 10:36 PM
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
no_ss
Sep 18, 2015 11:03 AM
