Why is my torque curve all jagged
Old Sep 15, 2010 | 09:39 AM
yellow dragon's Avatar
So I went for a dyno the other day and as you can see on my graph the torque line is all jagged. Question to all the tuning masters out there what couold cause this? Am I running lean, detonation, spark .....? Any Ideas
I am not debating the power I made there is a seperate thread for that this is for solving my torque curve issue. Thanks in advance.
http://i1211.photobucket.com/albums/cc437/mmccormick33/DynoSep13.jpg[/IMG]
Old Sep 15, 2010 | 09:42 AM
spitefulxcheerio's Avatar
running rich most likely. These cars from the factory come tuned rich cause they "run better that way"
GM rep told me that. You're probably running too rich at WOT. Did you blow off any smoke ***** in your higher RPM range when you did your dyno pull?
Old Sep 15, 2010 | 09:45 AM
mrbelvedere's Avatar
lmao he said smoke *****
Old Sep 15, 2010 | 09:46 AM
not myself though i did have a friend mention i puffed black smoke one day when he lost to me.
Old Sep 15, 2010 | 10:07 AM
rnjmur's Avatar
Does the car have any kind of tune at all? Your sig says you have the airbox mod and K&N, do you have any other mods? It could be a number of things... my first guess is that the fuel trims are probably way off but some more information about the car would help.
Old Sep 15, 2010 | 10:15 AM
Nope as far as I know thats it. The performance shop said it might have a custom tune but I have no idea I bought it used through a dealer who got it through an auction. i have check the pulleys and the injectors and they are stock. The shop was think fuel too but they were leaning towards it was lean.
Old Sep 15, 2010 | 12:57 PM
Bluelightning's Avatar
Got Bewst?
Time to get kennyspec to tune that thing! Thats where i would start
Old Sep 15, 2010 | 02:18 PM
I would love too, but I need a wideband first right. so save up a couple hun for that then what ever kennyspec charges etc..
Old Sep 15, 2010 | 02:32 PM
Area47's Avatar
Rent me! per hour
knock.
Old Sep 15, 2010 | 02:40 PM
stonny9's Avatar
that is high for just a filter and airbox mod.
Old Sep 15, 2010 | 03:00 PM
Got Bewst?
Originally Posted by Area47
knock.
That makes sense
Old Sep 15, 2010 | 03:06 PM
Cefaln452's Avatar
bingo
Old Sep 16, 2010 | 11:12 AM
Bika's Avatar
Fail Less.
This ^^^
knock.
and this ^^^
they only revved to 6000 according to the chart? even if its stock you should have another 500 rpm before teh limiter.
Does the s/c pulley have any bolts holding it on or is it pressed on the s/c shaft? Injectors green, or blue?
Old Sep 16, 2010 | 12:47 PM
Originally Posted by Bika
This ^^^
and this ^^^
Stock pulley, green injectors.
Old Sep 16, 2010 | 01:01 PM
jonathan923's Avatar
This car is on something weird lol. Thats alot for pretty much no mods lol
Old Sep 16, 2010 | 01:17 PM
ItalianJoe1's Avatar
Could be a high-reading dyno, or a tune with a lot of timing, causing knock and giving you the lumpy curve.
Old Sep 16, 2010 | 01:49 PM
Got Bewst?
His V Tec kicked in
Old Sep 16, 2010 | 10:18 PM
the secret is it's on red bull. Muhahahahaha
His V Tec kicked in
ecotec yo! Vtec how dare you!
Last edited by yellow dragon; Sep 16, 2010 at 10:18 PM. Reason: Automerged Doublepost
Old Sep 16, 2010 | 11:56 PM
Ecotec is only good for 220 stock. The extra power has gotta be vtec.
Old Sep 17, 2010 | 11:23 AM
Got Bewst?
Exactly
Old Sep 22, 2010 | 12:51 PM
Okay my power levels aside. Bluelighning said at the track I was blowing black smoke. So that means I am running rich right? So would putting the airbox cover back on help in terms of the MAF reading proper. Or should I get it checked at the dealer as it is still on powertrain warranty.
Old Sep 22, 2010 | 12:59 PM
Got Bewst?
You were blowing smoke on the way to Gimli actually haha. You should get a wideband and tune that biotch
Old Sep 22, 2010 | 01:35 PM
Oh I want too. But I want to wait for mods. and Arg! Cash flow!
Old Sep 22, 2010 | 01:37 PM
Bika's Avatar
Fail Less.
the air box cover will not skew your maf reading. If anything putting it back on will give slightly less air and make it slightly richer. You need to datalog with wideband and get a tune.
/end thread.
Old Sep 22, 2010 | 02:27 PM
Cool thanks well guess I gotta get a tune.
