why not smaller than 3"??
My question is why not go smaller than 3" on the pully? and if so what kind of problems will i be running into? because if i'm not mistaken the intense stage 3 kit uses a 2.6 or something like that.
First of all, stage 3 uses 2.8 which is almost near MAX to what the supercharger can handle with our redline (6500rpm). Second, you just can't slap a 2.8 on without any fuel upgrades because your engine will blow up (not literally but you get the point). They use a maf translator and fuel injectors to dump more fuel into the engine making it safer to run a 2.8. On a totaly stock car now, I belive the lowest you can go and still be somewhat safe is a 3 inch pulley.
patooyee
Oct 1, 2015 01:07 PM
brentil
Nov 12, 2005 05:42 PM
