Wideband question
Wideband question
I want to install a wideband before I add a stage 2 kit, just for peace of mind about leaning out. Can I swap out the o2 sensor for the AEM sensor? Will I start throwing codes if I do?
I suppose my only option then is to drill and have the fitting welded in....sounds like a PITA.
^^ can anyone confirm this? ^^
Edit:
The whole reason I want to get the wideband is because I'm getting the ottp stg 2 kit. I will be keeping the canned tune for quite some time. Will I even need to bother with the wideband to monitor the ottp canned tune?
Edit:
not until you are ready to do more to the car, such as another tune or meth maybe. my friends ott tune commands 11.8 AFR and gets 11.8-11.9. Ott did a good job on the tune
n20saturn
Sep 30, 2015 12:26 AM
