Wideband reading wrong(I think) HELP
Old Sep 26, 2011 | 09:09 PM
volsfan92's Avatar
Exclamation Wideband reading wrong(I think) HELP
I bought a Autometer Ultralite Wideband... Its reading stays between 14.6 and 14.9 all the time.. Does anybody know how to fix this or calibrate it? I tried their website to no avail.. Any help is appreciated
Link to manual http://www.autometer.com/download_instruction/1143A.pdf
Old Sep 26, 2011 | 09:20 PM
volsfan92's Avatar
Really need help by tomorrow
Old Sep 26, 2011 | 11:09 PM
volsfan92's Avatar
It worked fine for a week then started doing this today
Old Sep 26, 2011 | 11:13 PM
Chevycobaltss3's Avatar
When you get here il look at it
Old Sep 26, 2011 | 11:25 PM
volsfan92's Avatar
Ok but if its a sensor I'm fckd cause I dont have another one
Old Sep 26, 2011 | 11:27 PM
Do u have a check engine light
Old Sep 26, 2011 | 11:28 PM
volsfan92's Avatar
Yea P0420.. I guess from being catless
Old Sep 26, 2011 | 11:33 PM
If ure sensor is reading 14. All the time either the sensor is bad or 02 sensor for fueling.. Where is the first 02 sensor at is it still in exaust mani
Old Sep 26, 2011 | 11:36 PM
volsfan92's Avatar
Was working fine yesterday.. noticed today it stayed between 14.6 -14.9.. First sensor is in exhaust mani, second is in top of downpipe, wideband o2 is 3/4 way down the dp
I may have hit something in menu of gauge on accident but idk if it would case that
Old Sep 26, 2011 | 11:38 PM
Disconnect battery for 20 mins just cuz and recheck.
Old Sep 26, 2011 | 11:39 PM
volsfan92's Avatar
Ok I cant get tuned if the sensors fckd cause a new one would take 3 days to get here
Old Sep 26, 2011 | 11:52 PM
dumpleRL's Avatar
to check the sensor take it out of the exhaust spray a rag with some breakeen and put the tip in the rag it should go full lean, if it does not double and triple check all your wiring, if still nothing try another 02 sensor, my AEM did this and ended up being the sensor was shot
also im not sure on this but i know my AEM didnt need free air calibration but maybe the autometer does check the directions
Old Sep 26, 2011 | 11:53 PM
volsfan92's Avatar
Can I buy a sensor at like autozone?
Old Sep 26, 2011 | 11:59 PM
volsfan92's Avatar
Also i have it powered with wiper fuse.. where did u ground?
Old Sep 27, 2011 | 10:48 AM
G11's Avatar
G11
my aem just did this too just ended up being the sensor died
Old Sep 27, 2011 | 11:46 AM
volsfan92's Avatar
I hope the harness is just loose .. I'm getting tuned tomorrow.. Where did u ground yours?
Old Sep 27, 2011 | 11:49 AM
dumpleRL's Avatar
Stock radio ground strap
Old Sep 27, 2011 | 12:20 PM
volsfan92's Avatar
Could a bad ground cause it to just read in between those numbers?
Old Sep 27, 2011 | 01:56 PM
volsfan92's Avatar
Fixed the harness near o2 sensor unhooked itself
Old Sep 27, 2011 | 02:35 PM
Owen S's Avatar
You should put the O2 sensor as close to the engine as possible. Mine is the first sensor, followed by primary, than secondary. I get P0420 from "high-flow" cat, shouldn't matter to O2 sensor.
Old Sep 27, 2011 | 02:41 PM
outtamymind's Avatar
i was gonna say move your wideband sensor to before the cat and not after as you'll be getting scewed readings that way. and would make sense especially if your second O2 sensor is before the cat then that will through the P0420
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
n20saturn
Sep 30, 2015 12:26 AM
dennis69
Sep 28, 2015 02:16 PM
