Worst case scenario just happened in my engine
Fail Less.
when are you kids gonna learn. ZEX plugs are bad for our cars.
I highly doubt this is a "worst case scenario." do a compression test just to check but the engine is probably fine. just needs new threads and the correct spark plugs. maybe a coil pack.
The white **** on the coil and boot is just heat singe.
I just learned thats for damn sure. Please if anyone is researching plugs, learn from my screw up. DONT GET THESE THINGS.
How much do you think a compression test, threads and coil pack will run? I am really starting to think that the plug is the source of the problem, and GM wont warranty it at all. Suck.
Found the coil pack I think, although this site doesnt give me a PN...
http://www.newgmparts.com/partlocato...layCatalogid=0
Last edited by Johnboy12358; 02-15-2009 at 10:44 PM. Reason: Automerged Doublepost
Fail Less.
a compression test is free if you can rent the tool from autozone.
I have a coil pack but it doesnt have the rubber boot. You probably just need that connector boot
I'm concerned about where the pieces of the spark plug went. could have chipped up a valve or part of the cylinder.
my friend i work at vandergriff chevy. take it to us. i got...stuff lol on my cobalt and we dont really bitch. there cool there. just get it as stock as possible and i can even tell them ur my buddy. pm me if intrested. always glad to help a fellow balter out
Maybe I will start taking my car there. I have to bring my car in to have the hotside boost tubing replaced. Maybe we can set something up.
The oil on the boot on is probably just a leaking valve cover gasket.. not anything to worry about..
Have you tried scewing a new plug in # 1? Maybe you just left it loose the first time? (Hey, I've done it.. i'm not bashing..)
The burnt boot and all the dust is just from combustion gases escaping around the plug that wasn't screwed in!
This isn't worst case scenaro..
#37
Allot times stuff like that will pass no problem. IF a chunk did indeed fall off the plug at one the heat and compression will have most likely have disintegrated the piece before any damage occurs. It also could have worn over time and little by little pieces fall off and get sucked out with the exhaust gasses. Hell we have found pieces of the piston rings in the cat with no damage to the head on a failed engine. Pretty rare but in can happen.
And yeah, I am starting to think its not worst case, but that is where my mind went when I heard this thing pop! I didnt like it at all!!!
KIDS! DONT BUY ZEX PLUGS!
#38
Do your best to get the dealer to cover it. Have your dad or someone go with you and help you out. Take all things off that could result in them blaming a mod. Changing spark plugs won't result in terminating your warrinty. BTW, I always knew ZEX plugs sucked. NGK is the only brand to use IMO.
#40
#41
Resolution!!
Ok, so I had to take the car to a shop. The threads in cyl 1 were completely gone, like none at all. They were able to put in a solid insert to re-thread it. They checked the threads on all the other cylinders and they all looked good, everything is sealing up. After the insert was put in, I had them put in my NGK BKR7E's gapped at .035". Damn, it runs way better now, and I mean better than before it blew up...
The piece that broke off of the #1 went through without foul as well it seems.
Moral of the story kids?
DON'T BUY ZEX PLUGS!!!!
Anyways, here are some pictures of the damage, and the total piece of **** plugs that came out. It seems that they had all started to back out, or were knocked loose when the first one went. The plug holes had exhaust residue on them, as do these things...
All four, plus the blown up coil pack.
Check out the stripping... It took all the threads out, I mean ALL of them.
If you look here, you can see where the force of it gettin blown out actually ripped the rubber of the coil pack's boot apart all the way at the top. There are four places around the top where it is torn like this.
Here are some close ups of the other three. These things were ****.
Thanks to everyone who helped me out with this!
#43
dont use any plugs with multiple electrodes or whatever. this is mine. my gf's dad builds engines and he said those kinda plugs arent designed to be run in supercharded cars.
#44
Huh, this is just what the second post in this thread said to do.
#49
I paid, the problem was caused by the spark plug, I am positive. I decided to not mess with the dealer, the place that fixed it had a decent price and they seem knowledgable
