Is it worth or regret going to Meth?
Old Sep 24, 2009 | 03:04 PM
rcorona8's Avatar
hello guys, do any of you regret going to METH INJECTION?
i HEAR people blowing their motors/pistons, i don't know how true this is.
i know there are great advantages but i still need ur opinions? i do know you need a TUNE. thank s
Old Sep 24, 2009 | 03:12 PM
Jn2's Avatar
Jn2
meth lowers IAT2's, i dont think its the cause of blowing engines, u wont blow from going rich, atleast it wont be as easy as going lean, chances r the tuning was crap if they blew and blame it on meth
Old Sep 24, 2009 | 03:15 PM
Spectral's Avatar
Meth is great for our cars. Does an awesome job cooling the air. Don't know what you mean about blowing motors just be careful and get a good tune and just don't run outta meth
Old Sep 24, 2009 | 03:18 PM
Jn2's Avatar
Jn2
very true if your tuned for meth, if you run out, ur engine will go lean and possibly blow
Old Sep 24, 2009 | 03:24 PM
freakta's Avatar
best thing for the car is meth... just get it and dont run out
Old Sep 24, 2009 | 03:33 PM
Rodimus_Prime's Avatar
i dont see how anyone could possibly regret it
Old Sep 24, 2009 | 03:43 PM
06cobalt_ss's Avatar
Meth is great! I have the devils progressive kit and it is awesome!
Old Sep 24, 2009 | 04:03 PM
rcorona8's Avatar
what happens when if you run out of meth and you don't know and you run at WOT???
Old Sep 24, 2009 | 04:08 PM
2K5SS/SC?'s Avatar
^^^ You end up with a blown motor if you are tuned aggressively on it.
Old Sep 24, 2009 | 04:12 PM
JAYNO20's Avatar
how long does meth usually last? assuming I have a tank in the car that is filled to the top...
Old Sep 24, 2009 | 04:15 PM
EXsoccer1921's Avatar
i'm tuned for 90/10 meth/water @10gph. and theres people tuned even more aggressively. i haven't blown up. nor will i. plus...if you're really worried about it, just keep your back seats down and turn your head and look at the damn tank.
Old Sep 24, 2009 | 04:51 PM
freakta's Avatar
there is a level indicator so you know when you are low.
if you dont tune for it then you wont have a problem running out, if you tune agressivly for it and run out you could have big problems.
my tank with 4 injectors lasts 2-3 months but i dont hit the gas just to hit the gas, some people run out in a day
Old Sep 24, 2009 | 04:58 PM
rcorona8's Avatar
i guess it would take a complete idiot to blow your motor!!! what are the chances of a line or nozzle clogging?
Old Sep 24, 2009 | 05:00 PM
freakta's Avatar
depends on how dirty your car is... but its got to be pretty low percentage
Old Sep 24, 2009 | 07:46 PM
cli3e0339384398jk's Avatar
i was worried about it when i first got it but if you have the proper monitoring equipment you will be fine........wideband, interceptor. I have mine activated for an 8-9psi kick on with the tvs and it can last for a long time or 3 days, depends if i stay out of boost or not.
Old Sep 24, 2009 | 10:59 PM
rcorona8's Avatar
Isn't it the same thing . Interceptor N Wideband?
Old Sep 24, 2009 | 11:13 PM
06cobalt racer's Avatar
nope 2 different gauges
Old Sep 24, 2009 | 11:43 PM
rcorona8's Avatar
What do each read?
Old Sep 24, 2009 | 11:44 PM
the interceptor CAN be a wideband gauge though if you bought the sensor
Old Sep 25, 2009 | 12:00 AM
What do each read?
interceptor reads a lot of different things. a wideband reads the afr.
Old Sep 25, 2009 | 04:41 AM
Zach06CobaltSC's Avatar
The reason people blow there motors usually when they run out of methanol and go wot is because they have there timing advanced quite a bit. Methanol helps suppress detonation and has a very high octane rating, this in return allows you to run more timing. However if you are running a lot of timing, say 25 degrees and run out of methanol, you will more then likely see SEVERAL degrees of knock which can result in blowing your motor if you keep your foot in it, also there is the aspect of going lean, but usually its the knock that does it.
Old Sep 25, 2009 | 09:12 AM
johnladow07's Avatar
Methonal made a night and day difference in my car. I am now running a 50% mix instead of the windsheild wiper fluid and I upped the timing quite a bit. My aggressive tune holds 24 degrees no problem. I have ran 25 with no knock but bumped it down a hair to be safer. When Im Daily driving I run 22 degrees of timing. Overall I have no regrets about using methanol. I say go for it
Old Sep 28, 2009 | 04:45 AM
hawkesb3's Avatar
what is the hp increase advantage in running meth... tuned and untuned ?
I am going stage 2 soon and want to run meth.
Old Sep 28, 2009 | 08:54 AM
383_Stroker's Avatar
Methanol is a pain in the butt (because i'm paranoid of running out, clogged nozzles, popped fuses, etc).. Lol... But I've got it and I'll never go back without it!..
Old Sep 28, 2009 | 02:16 PM
hawkesb3's Avatar
what kind of hp increase did you get with meth
