wtf???
wtf???
So i just gone done changing my oil
i disconnected some sensor thats between the supercharger and the motor then connected it again and i reseted my oil life
and when i turn on the car the check engine light is on?
does anyone know what this could be or how i could take the check engine light off?
then u plugged it in but its still there
imma jus do dat reset the battery
thx guys
put it this way. if you change the battery on a car, does it erase the ECU? I've heard of putting a battery on in the wrong order and it frying the ECU, but your just disconnecting the Negative side for a few seconds.
I would only put 6 in I would not put 7 manly because if you over fill your car and when it start to build up crank pressure it send oil through the intake there for going through the super charger and causing white smoke to come out the exhaust
Getaway_Driver
13
Aug 30, 2015 02:44 PM
