wtf mate, car not running properly
Old Jun 2, 2009 | 10:33 PM
G_Pelly's Avatar
hello everyone,
i have a 06 ss/sc with gm stage 2 airbox mod, magna flow muffer and torque dampener. and ngk one step colder plugs gapped at .38.
when ever i run the car hard, full throttle it runs fine, but ill stop at a light or something. ill take off and my car will bogg, ill give it almost floor it and it will feel like i wont go any where till about 3 or 4 grand and then car will take off what seems like normal, but even in second and third gear, it seems like the car is really bogging before 4 grand
i have also had it one time. it seemed like the supercharger wasnt working at all. the car was still boosting 15 psi but the car wasnt going anywhere and i was around 5 grand and just seemed like there was no power at all.
also i think this is normal for stage 2. ill boost 15psi and it will stay then start to climb till redline, when i shift i see about 17psi at redline in second gear.
the most recent things i have done. is put those spark plugs in, and it has done this before the spark plugs too. and i took out my left fog light so its like ram air in my intake, but i dont think that has anything to to with it
im trying to give you all the information that i have. and i think that is it.
does anybody have an idea whats going on. i have thrown any codes at all so its really hard to tell whats going on.
Old Jun 2, 2009 | 11:09 PM
Zach06CobaltSC's Avatar
Bad cat.
Old Jun 2, 2009 | 11:42 PM
GTPUSER's Avatar
Misfiring somehow? Get a scanner to see, if you don't want to spend too much money get one of these http://www.davisnet.com/drive/produc...asp?pnum=08226 and you can post the results.
Old Jun 3, 2009 | 12:38 AM
G_Pelly's Avatar
if i get this what will it monitor/tell me that will help me figure out whats wrong with my car, will it moniter my spark and my fuel? i just dont want to spend 120 bucks on something that i dont know if it will help with my problem
Originally Posted by Zach06CobaltSC
Bad cat.
you think its the cat? i was kinda thinking that, but i did the old hit test and didnt hear anything rattling, could it be clogged? and wouldnt i throw a code if the cat is bad
Old Jun 3, 2009 | 01:11 AM
Cats can go bad without giving codes. Do you have a check engine light? Do NOT buy that think gtpuser linked above, its worthless. If you have a code get it read from autozone for free. The reason I am thinking its your cat is because of the amount of boost your pushing on a stage 2 pulley, its pretty high. Try to do some general maintenance first, clean the throttle body, clean the maf, clean the air filter, change the plugs with ngk bkr7e's, change the fuel filter and all that crap. That stuff is really cheap and easy to do so even if it doesn't solve your problem its preventive maintenance. I still think it might be your cat though.
Old Jun 3, 2009 | 02:59 AM
G_Pelly's Avatar
I do have those plugs the throttle body is pretty new, it had to be replaced cause it was putting me into reduced power mode, there is no check engine light so I don't know what to do
Old Jun 3, 2009 | 09:21 AM
ShortStack's Avatar
How is 15psi high on a stage 2 pulley?
Stock is 12.
Old Jun 3, 2009 | 09:29 AM
He is hitting 17psi on gm stage 2. That's a lil high lol.
Old Jun 3, 2009 | 09:49 AM
ShortStack's Avatar
Ah.. didnt read the sentence down... Yea 17 is a little iffy.. i hit that with the 2.8.
Old Jun 3, 2009 | 11:27 AM
G_Pelly's Avatar
Yah 17 psi at redline on stage 2
Anybody else think they know whats going on?
Old Jun 3, 2009 | 11:32 AM
Bika's Avatar
Fail Less.
bad cat. cut it off.
Old Jun 3, 2009 | 06:27 PM
nicksredline's Avatar
yeah i would say a cat... just punch it out and get it over with... free. little more power... ugly sound IMO i hate non cat but i still run 1 my self lol... gm stage 2 run's ritch ... causing ur cat to clog./
Old Jun 3, 2009 | 06:53 PM
G_Pelly's Avatar
Ok, ill have to try that, what do I use to punch it out like a pipe? And if I just wanted to get a catless down pipe who makes the best une that will bolt on the a stock exhaust?
Old Jun 3, 2009 | 09:36 PM
Bika's Avatar
Fail Less.
zzp, cobalt addiction, clear image, CTI, Hahn
Turbo Johnny
Feb 21, 2019 09:41 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
TurboWood
Sep 7, 2015 11:08 AM
Adam144
Sep 3, 2015 07:48 PM
soundjunky
Sep 3, 2015 01:18 PM
