ZZP BRFPS,...help :/
Old Oct 3, 2016 | 06:28 PM
315SS's Avatar
ok so long story short, I installed this along with a tvs and 80# injectors, have been through hell and back last few weeks dealing w/ sending unit issues etc.
that's all finally squared away and pcm for the time being has been updated by zzp. but when I turn my key on sounds like when fuel pumps pressurizing systm that air is being sucked in by the fuel pump then after 4-5 sec sounds as it should.
then when trying to actually drive the car when I try and give it some throttle car feels restricted like cant get air,...boost goes up to about 18psi but car goes no where. then after letting off throttle car seems to almost want to stall, then adding even the slightest bit of throttle makes the car sound and feel like its flooded or something of that nature, even letting off a hiccup type back fire........
anyone with experience with this topic input is appreciated, ill post my terrible pic diagram of how ive got the brfps hooked up. being there is no info anywhere or diagrams in existence I think ive got it hooked up right but who the hell knows at this point.
Old Oct 6, 2016 | 10:11 PM
Stumpalump's Avatar
What's your plug gap? It needs to be small. By your description, are you thinking the fuel is aerated? Run the return into a bucket and look for air if so.
Old Oct 6, 2016 | 10:29 PM
Stumpalump's Avatar
The cheap little fuel pressure gauges that get plumbed in right before the fuel rail should be on your car. Not an option in my opinion especially with the extra piece parts you added. Sorry if that insulted your intelligence and you know the pressure is right.
Old Oct 7, 2016 | 03:10 AM
Sharkey's Avatar
whats your wideband showing? you have one, right? thats pretty much a must with your setup.
Old Oct 10, 2016 | 07:21 AM
315SS's Avatar
Mod list below, but yes I have a fuel pressure gauge on the rail that reads between 38-42 @. Idle.....
Wideband reads halfway decent, 14.2-14.8 under normal throttle and idle conditions,
Plugs are ngk iridium ix's 1 step colder gapped @ .035
Thinking maybe got bad gas? Running Sunoco gt 260 plus 104 octane ATM
Tried some dry gas and filled tank rest of the way w/ 93 pump gas last night and seems to be coming around, but stikl sometimes after accelerating under boost will start misfiring now?
Air bubble sound is coming from regulator when ignition turned on,....possibly have brfps routed wrong? Dfk
Engine Air
ZZP Polished Stainless 3" Cold Air Intake
Weapon-R Secret Weapon Air Filter (10" Tall, 6.5" Wide, 3" Inlet)
ZZP LSJ LS4 Throttle Body
ZZP LS4 TB Coupler
HARROP TVS 1320 LSJ Supercharger
ZZP 2.8" TVS Modular Pulley
ZZP LSJ 1/2" Aluminum Intake Manifold Spacer Plate
ZZP Long Tube Header 1.75" Primaries, 3" Exit Flange
ZZP 3" Down Pipe (W/O Cat)
ZZP 3" Stainless LSJ Cat back Exhaust
ZZP 3" Stainless Resonator
ZZP 3" Stainless Muffler
ZZP Valve Cover Breather
DEI Titanium Header Heat Wrap (Header & Down Pipe)
-Engine Fuel
ZZP Boost Referenced Fuel Pressure System W/
Fuel Lab 515 Fuel Pressure Regulator
Fuel Lab Fuel Pressure Gauge On Rail
AEM 320 IPH High Flow Fuel Pump In Canister
Siemens/Mototron Deka IV 80# Fuel Injectors
ZZP Ev1 Injector Adapter
OTTP Fuel Pump Rewire kit
Sunoco GT 260 Plus Race Fuel (104 Octane Unleaded)
-Engine Ignition
ZZP LSJ 47KV Ignition Coils
NGK Iridum IX Spark Plugs (Standard Heat Range, 7)
ZZP Alternator Voltage Booster
Interstate Batteries MEGA-TRON
-Engine Intercooling
ZZP LSJ Stage 3 Front Mount Heat Exchanger
ZZP Stealth Aluminum Heat Exchanger
ZZP Dual Pass Intercooler Plate
ZZP Option B Dual Pass Kit
ZZP LSJ Oversized Aluminum Radiator
ZZP Silicone Upper & Lower Radiator Hoses
ZZP LSJ Phenolic Intake Spacer
ZZP LSJ Upgraded Laminova O-Rings
2) 1750 Cfnm 7" Intercooler Fans
2) 1800 Cfnm 12" Radiator Fans
Lucas Super Coolant Added To Radiator & Intercoolers
-Engine Internals & Supercharger
COMP Cams (ZZP SC Stage 2 Camshafts)
ZZP 82# Valve Springs
Supertech Extreme Flow Stainless Steel Performance Valves
OTTP Balance Shaft Delete Kit
ZZP Titanium Valve Spring Retainers
Ecotec Viton Upgraded Valve Seals
ZZP Ecotec Valve Locks
ARP Head Studs
ARP Timing Bolts
Cometic Multi Layer Steel Head Gasket
ZZP Adjustable Tension Arm
ZZP PCM 1.0
ZZP PCM Update (3x)
ZZP ECOTEC Turbo Oil Pan +.5 Quarts
K&N High Flow Oil Filter
ZZP Magnetic Oil Drain Plug
Royal Purple Fully Synthetic 5W-20 Motor Oil
-Drivetrain & Brakes
EXEDY Stage 3 Hyper Single Clutch Kit
ATI Super Damper OD Crank Pulley
GMPP Upgraded Throw Out Bearing
ZZP Throw Out Bearing Spacer Plate
OTTP Stainless Short Throw Shifter
OTTP Stainless Shifter Cable Clamps
ZZP Revised LSJ Shifter Bracket
OTTP Stainless Base Bushings
ZZP Front Cross Drilled & Slotted Rotors
ZZP Rear Cross Drilled & Slotted Rotors
BF Goodrich g-Force R1 Competition Drag Tires 245/40R18 (Front)
Goodyear Eagle Sport All Season 215/45R18 (Rear)
Royal Purple Transaxle Fluid
-Suspension
D2 Racing RS 36 Way Adjustable Front Coil Overs
Eibach Sport Line Lowering Springs -2.5"R -1.7"F
ZZP Front Strut Tower Bar
OTTP F35 Upper Transmission Mount (Alum & Poly)
OTTP Front Rotated Transmission Mount (Alum & Poly)
OTTP Rear Rotated Transmission Mount (Alum & Poly)
ZZP Billet Aluminum Upper Motor Mount
OTTP Stainless Steering Rack Spacers (1&1/2"-2") Drop
MOOG FE3 Control Arms (D&P Sides)
ZZP Solid Control Arm Bushings
MOOG Outer Tie Rod Ends
Energy Suspension Solid Poly Sway Bar Bushing & Bracket
-Interior
ZZP 3 Pod A Pillar Gauge Holder
AEM Boost/Vacuum Gauge +35/-30
AEROFORCE SS Interceptor Scan Gauge
AEM UEGO WideBand AFR Gauge
Bully 4 Panel Push Button Switches
Pioneer 7" Touch Screen Head Unit
2 Tone Red and Black SS Embroidered Bucket Seats
Red LED Peddle Lights
10" Kicker Comp-VR Subwoofer
Sub Enclosure Custom Mounted Into Trunk Liner
Alpine 500 Watt Mono Block Amplifier
Soche 500k Farrad Digital Capacitor
-Exterior
Aluminum Billet Grilles Both Upper and Lower
Black WCC Mesh Behind Grilles
20% Tinted Glass
Depo Black Housing Triple Beam Projection Headlights
20% Tinted (Tail Lights, Side Markers, Reverse & Turn Signals)
MPx Shorty Antenna 5"
White SS & Bowtie Emblems
Sylvania ZxE Headlights and Fog lights
Sylvania Silver Star Bulbs (3rd Brake, Side Markers, Reverse, License Plate)
Phillips LED Bulbs (Red Turn Signals, Red Brake Lights)
Rubberized Sound Dampening Undercoating Full Under Body, Frame & Front End
Old Oct 12, 2016 | 12:19 PM
mrbelvedere's Avatar
Engine Air
ZZP LS4 TB Coupler
-Engine Fuel
-Engine Ignition
ARP Head Studs
ARP Timing Bolts
ZZP PCM 1.0
ZZP PCM Update (3x)
-Suspension
-Interior
-Exterior
20% Tinted Glass
it might be the black wcc mesh behind the grilles causing you problems
Bluelightning
Sep 12, 2016 02:55 PM
WVU_SS
Sep 7, 2016 08:03 AM
05RLS2
Aug 29, 2016 05:57 PM
Haven07
Aug 20, 2016 08:05 PM
05ZZP
Aug 19, 2016 11:03 AM
