ZZP Header installed and now it idles different
Old Apr 14, 2008 | 08:14 PM
Cam1979_99's Avatar
I installed a ZZP shorty header the other day and now my car idles rough as hell. Can someone help me?
Old Apr 14, 2008 | 08:15 PM
XM15's Avatar
How does it idle funny? Is it just the sound, or do the RPMs bounce around?
Old Apr 14, 2008 | 08:30 PM
Cam1979_99's Avatar
Just idleing the rpm's hop up and down a bit. Starting it and letting it idle it acts like it wants to die on me and im not sure whats goin on. When i go to take off sometimes it does it bad to the point of making my car almost dying
Old Apr 14, 2008 | 10:37 PM
Bumpin Balt's Avatar
I noticed this same issue when I installed my GMPP exhaust. It feels like I have less control with the gas pedal at low rpm's.
Old Apr 14, 2008 | 11:03 PM
Cam1979_99's Avatar
Did you ever get the problem fixed?
Old Apr 14, 2008 | 11:51 PM
No. I just installed the exhaust on saturday. I've heard that some guys are bumping their idle rpm's up a bit with HP tuners and it solves the problem. If you know someone with HP tuners they might be able to help you.
Old Apr 15, 2008 | 01:50 AM
jwolf8604's Avatar
Bump for a good guy. I sold this header to him and didn't have any problems with the header on my car. I feel bad that he is having problems with it.
Does anyone know how an increase in air flow could be messing with his idle rpms or if that is even possible? Also is it possible that somebody had a tune on the car before he bought it and that is the problem? How would he be able to tell? Good luck cameron.
Old Apr 15, 2008 | 01:53 AM
KillerBee's Avatar
valves and rings could be messing up only thing i can think of i thought i read somewhere somebody had issues after they installed there header and dp with there valves i could be wrong
Old Apr 15, 2008 | 05:27 AM
HunterKiller89's Avatar
less of a scavenging effect due to the larger primaries? causing the RPMs to drop, which tells the ECU to open the throttle a little more to keep the engine from dying, which makes the RPMs go up, which puts the car back at square one, so the throttle closes, since it thinks the "near engine dying" is over. repeat about every second
again, this is just my guess, but it seems quite logical to me..
Old Apr 15, 2008 | 05:31 AM
DoubleLP's Avatar
Pull the negative off the battery for at least 15 minutes and put it back on to reset the computer. Probably just needs to learn the new air flows that are happening now.
Old Apr 15, 2008 | 05:51 AM
BRN169's Avatar
^^^ What he said, the car knows something is different than what it has learned and it is trying to compensate. This will dump what it has learned and force it to relearn how to run without anything to compare with. When I first had my header and dp installed the car was all over idling high then low then surging. It stalled once or twice at lights. As soon as I got home I shut it down and disconnected the battery for a while. It was fine after that except for a CEL that would pop every now and then. Ultimately you are gonna want to get it tuned to really get the most out of it.
Old Apr 15, 2008 | 07:24 AM
distillion's Avatar
i have the new shorty header.
never had an issue.
Old Apr 15, 2008 | 06:52 PM
Cam1979_99's Avatar
I did take the negitive off 4 20 min and it did not help!!!
Old Apr 15, 2008 | 08:09 PM
Nyke's Avatar
Check for exhaust leaks, if your getting a exhaust leak at the header it will probably suck in air than suck it out tellign your O2 senson your running lean, then it will jack up your idle, then your computer will see the idle RPM and say thats not right! and lower it, and the cycle continues.
Old Apr 16, 2008 | 12:12 AM
Cam1979_99's Avatar
There is not any leaks. I have a warranty so i will take it to gm and see what the hell they have to say.
Old Apr 17, 2008 | 11:11 PM
Cam1979_99's Avatar
Thanks to all that tried to help out> Took it in and the 02 sensor was bad. They didnt have it in so its getting fixed tomorrow and then ill see how the header works.
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jas09ss
Sep 26, 2015 01:06 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
