zzp lysom upgrade...
if you have all the stuff already then i would assume you can choose lsj.... while your at it, tell zzp to pop in here
Mr B, do you have any more input on this blower setup ?
thoughts opinions ?
similar to a turbo setup on an lsj i would assume ....
Last edited by yellowsupercharged06; Feb 10, 2014 at 11:07 AM. Reason: Automerged Doublepost
Opposite. You would want a short drain so you would want to tap the front of the pan instead of the back like you would for a turbo lsj
We only have one. we're not pushing SC upgrades because they don't compare to turbo builds. 2k+ is a waste on an LSJ if you don't go turbo.
2.2/2.4 kit comes with new LSJ intake manifold/endplate with IC cores, Bosch IC pump, lines, FMHE, injectors, throttle body, some adaptors.
what detail do you need what do you think the 1000 extra for the 2.2/2.4 is for its for a manifold and such
tvs is just soo expensive, i bet alot of us cheap lsj guys would definately hop on this upgrade instead.
