ZZP S3 vs OTTP S1 Heat Exchanger ?
Hey Guys, I wanted to know if any of you had experience text run either ZZP S3 or OTTP S1 Heat Exchanger ? Which one is faster recovery time that cool IAT down ? Wanted to hear out what is your experience and opinions ?
I have zzp S3 heat exchanger, put on at the same time with dual pass and opt B, and I don't really see much rise in IAT2'S but I am on the stock pulley still... On a side note, the zzp's are durable as hell
Pretty sure zzp did a comparison with all other heat exchangers.. But I have zzp s3 and it does a phenomenal job. I just don't like how the paint zzp on it :/ oh well. It does the job I want it to do
hey screw it, just put a 2.5 on that sounds legit
if you have no cooling mods there's no reason to go to a smaller pulley "because you just lower the timing so there isn't any knock". that just mean you have a 220hp 2.8 car.
cooling mods just seem unecessary if you plan on keeping a 2.8 inch pulley or higher. i still command 17-18 degrees of timing up top. just not the 20-22 degrees that you do on stage 2. which i did see kr at anyways
Well, I think the Cooling Mods help recover IAT time faster if you have the cooling mods. Suppose I want to keep hitting it and feel the boost everytime then cooling mods would do it. That's what I think, maybe I am wrong or right but I do think Cooling Mods are worth it. Just as long take it 1 at it time to get it where you want it to be. That's what I am doing. I got Dual Pass, Phenolic Spacer, and Option B Tank right now in my car but going for ZZP S3 Heat Exchanger then I am good.
