ZZP stage 3 kits
ZZP stage 3 kits
I have GMPP stage two kit on my car now, with a ZZP intercooler. 60 lb injectors. What all do I need to step up to stage 3 ZZP and is it even worth the money? I plan on having enough money after I buy either a CTS-V or a TBSS, to do so mods to the balt. I know the trans, is going to be a weak link, but as long as I am careful, is it worth it?
Pretty sure if you already have 60lb injectors you could just slap a 2.8 pulley on it and have what a stage 3 kit could get you. You would need a tune tho. The stock trans should survive more abuse then a stage 3 kit can give it unless you rot the hell out of it.
If I use a trifecta tune, would that work? The trans shifts fine. Ill be upgrading the shifter this week. Stocker is way to sloppy for me.
Trifecta can tune you for the pulley. I still have a trifecta tune with my TVS since i have no one around that knows anything about hp tuners. I may not be getting all the power out of it since trifecta is conservative. But I have used them with every mod Ive made. Started out with 60s and a 2.8 down to a 2.6 with meth inj and now the TVS. I have no complaints. The car hauls ass. lol What shifter are you getting?
You need a lot more than a stage 3 to break a trans unless you walk around with a helmet on the daily
The car has a exedy single clutch kit that has 3k miles on it. The trans itself and the half shafts are all that worry me. I don't do any drop launches at a light. I dig only. As long as I hook, and don't over rev/miss a shift I should be fine correct?
wheel hop is what kills axles and sometimes transmissions more then anything. There are a few places that sell rotated trans mounts. They are pretty much a necessity for eliminating wheel hop lol. I got a set of stage one axles from zzp when i did my gmpp clutch kit. Haven't broke one yet, but I'm easy on the car from a dig.
Lets hope not with the way I drive.
Cool starry bra
