ZZP vs GM Dual Pass Plate
Assuming you're not still under warranty, yes. Then again they probably won't even notice it even if you take it in for warranty service with someone else's plate on there.
Yes dont bother with the expensive dual pass end plate. Go with the OTT performance endplate for a little over 100$.
Yes they both do the same thing (lower the IAT2) but they do it different ways. h/e cools the water temps more due to the higher efficient h/e and the dual pass has two pass's of water through the intercooler instead of one.
Stock endplate passes 4 times.
Dual pass, well.. passes twice.. which shortens the time the coolant is in the intake manifold.
One inlet and one outlet is stock (thats what I meant when I said path), dual pass is two inlet and basically two outlet (even thought there is only one hose connects out).
But you are correct, stock is 4 passes.
WRONG. dual pass two passes. OEM FOUR PASSES.
