05 sedan driving light crap
Old Dec 2, 2008 | 01:01 AM
musifreak190's Avatar
its been in an accident and i fucked up the lower control arm on the passenger side but i know it will drive good again one day. going over bumps used to be so smooth and and its like . so ive had the sway bar links and bushings replaced and it took away alot of noise but the is still sloppy and after driving in my friends 02 civic it really pissed me off. So now i want to replace the struts and shocks im gueesing and Im wondering if I should go with the SS struts and shocks. Now ive seen the list of swappaple parts from the lsj but If i just wanted to make my 05 2.2 sedan drive decent again do you think fe5 shocks, struts, and springs would cover it? or am I gonna have to order a crap load of parts to cover it. Im not looking for complete ss handling?? If its just a matter of ordering two struts and two shocks and springs this will be happening soon, if theirs alot involved maybe not.
Input would be awsome...sorry its my birthday and im kinda drunk
Old Dec 2, 2008 | 01:04 AM
bryce712's Avatar
1st off happy bday ! and you should be fine with just the fe5 parts and swapping them unless there is something else causing it to drive that way
Old Dec 2, 2008 | 01:10 AM
Jn2's Avatar
Jn2
you can swap the SS strusts and shocks fine, if your buying used, get those, if you buying them from a dealer, or from a vendor, ur better off buying urself some koni yellows
http://www.turbotechracing.com/produ...dcategory=5627
^^rear
^^front
but if your buying used like i said go for it, but new, the cost of new SS vs. Koni i woudl dave for koni
Old Dec 2, 2008 | 11:13 AM
koni yellows will look into it....and thank you!
those konis front and rear are struts?? The rear struts wont have any problems replacing because I got shocks in the back...thanks again!!
do you think its worth buying these off ebay their 200 dollars a pop?
Last edited by musifreak190; Dec 2, 2008 at 11:13 AM. Reason: Automerged Doublepost
Old Dec 4, 2008 | 11:54 AM
nvm those were inserts.....do the koni kits from TTR come with lowering springs?
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
maliki778
Oct 1, 2015 07:39 PM
